Results 1 to 15 of 15
Thread: 2015 versa
    epd1221's Avatar
    Nov 2011
    usa
    Default 2015 versa
    hello here i got a 2015 Nissan Versa 98820-9ke0A with 95128 eeprom inside i try clearinng no luck i get code B1090
    2015 Nissan Versa
    98820-9KE0A
    95128
    May 2014
    try this and report bro
  3. The Following User Says Thank You to borjapoo For This Useful Post:
    epd1221 (13th November, 2018)
    epd1221's Avatar
    Nov 2011
    usa
    Still getting hard codes ..
    B1209
    B1210
    B1211
    B1298
    dmka's Avatar
    Oct 2013
    Vatican City
    Your crash doesn't look original... but try this, if your file was original untouched, then my file will work 100%
  6. The Following User Says Thank You to dmka For This Useful Post:
    epd1221 (14th November, 2018)
    epd1221's Avatar
    Nov 2011
    usa
    No more codes just ligt flashing . no dtc on unit ..
  8. #6
    dmka's Avatar
    Oct 2013
    Vatican City
    I did't like your "original" file, try to find and clear one from another car.
  9. The Following User Says Thank You to dmka For This Useful Post:
  10. #7
    swiderek's Avatar
    Jul 2017
    CHICAGO
    try this and report
  11. The Following User Says Thank You to swiderek For This Useful Post:
  12. #8
    epd1221's Avatar
    Nov 2011
    usa
    Same no more codes what so ever srs light flashing only. What I notice my autel or snap on don't have occupant sensor option maybe that's the problem that i have to calibrate seat
  13. #9
    superjet's Avatar
    Aug 2018
    try this and report
  14. The Following User Says Thank You to superjet For This Useful Post:
  15. #10
    epd1221's Avatar
    Nov 2011
    usa
    Your file same no codes on system srs lighy flashing rapidly. Run out of ideas .. Check all wiring Everything is good
  16. #11
    superjet's Avatar
    Aug 2018
    try this and report
  17. #12
    Oct 2017
    epd1221 did you fix the problem br
  18. The Following User Says Thank You to long beach For This Useful Post:
    epd1221 (15th November, 2018)
  19. #13
    epd1221's Avatar
    Nov 2011
    usa
    im about to try file on vehicle
  20. #14
    epd1221's Avatar
    Nov 2011
    usa
    Long beach try clear 2 and same results no codes srs light flashes .. Very weird car first time this ever happens
  21. #15
    Oct 2017
    Default 2015 versa
    ok I use this 100% work for me try
  22. The Following User Says Thank You to long beach For This Useful Post:
