Hi, have you ATM or Manual GB...?
Nothing special with your cas dump, search for other flash file...
- Hi friends, after trying to encode a second key in a 320 e90 bmw with FVDI the car does not start, I receive code A0AD processor in CAS2, please I need help, attached eeprom 2k79x
synchro egs cas - OKĄ
synchro dme cas - not okĄ
6135-6943791
FSV 6.3.3
OSV3.3.0
HWW03
SW30.0
COD 05
DIAG-Index 6A0
5WK4 9412OBF
mask 2k79x
[CITA = dijo; 3421824] Hola, ŋtiene usted ATM o Manual GB ...?
Nada especial con su volcado de cas, busque otro archivo flash ... [/ QUOTE]
Manual gear box
the problem is in the eeprom, I have loaded another eeprom of digital-kaos and disappear processor failure, please some could encode everything necessary from the defective file to the donor file? attached files
Best option for you change ISN in new cas eeprom write to cas make key " don't use better FVDI" do coding and synch
crisvenua2 (15th November, 2018)
What is the best tool for coding keys in E90? I managed to graft the 2 files and the processor failure disappeared, copy the synchronization code and the car starts, thanks to all
Is it possible that someone can tell me the 3 hex codes of the 3 keys stored in the first file?
hello I do not have problem of the file I only want to put the code of a second key, for that reason I want to know the position of the codes of the key in the file, thanks
