5V regulator is the component in the right below side with mark L7805CV
Greetings,
I need photos of pcb with components on it.
I can only see on mine 74hc125 and the rest is blurred.
I have problem with all test failed:
5V Tests. Close J1 and press a key to continue
Test1: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=0,00V, P2=1,03V (H), P3=0,00V (L), P4=0,00V (L),P6=1,03V (H), P7=0,00V (L), P8=0,00V (L), P9=1,74V
P2(1,03V ) not in 0,00V - 0,25V
P6(1,03V ) not in 0,00V - 0,25V
P9(1,74V ) not in 0,00V - 0,25V
Test Failed
Test2: P1=8V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=4,69V, P2=0,40V (L), P3=0,00V (L), P4=0,00V (L),P6=0,40V (L), P7=0,00V (L), P8=0,00V (L), P9=0,69V
P1(4,69V ) not in 7,70V - 8,30V
P2(0,40V ) not in 0,00V - 0,25V
P6(0,40V ) not in 0,00V - 0,25V
P9(0,69V ) not in 0,00V - 0,25V
Test Failed
Test3: P1=9V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=4,69V, P2=0,21V (L), P3=0,00V (L), P4=0,00V (L),P6=0,21V (L), P7=0,00V (L), P8=0,00V (L), P9=0,37V
P1(4,69V ) not in 8,70V - 9,30V
P9(0,37V ) not in 0,00V - 0,25V
Test Failed
Test4: P1=10V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=4,69V, P2=0,11V (L), P3=0,00V (L), P4=0,00V (L),P6=0,11V (L), P7=0,00V (L), P8=0,00V (L), P9=0,19V
P1(4,69V ) not in 9,70V - 10,30V
Test Failed
Test5: P1=11V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=4,69V, P2=0,06V (L), P3=0,00V (L), P4=0,00V (L),P6=0,06V (L), P7=0,00V (L), P8=0,00V (L), P9=0,11V
P1(4,69V ) not in 10,70V - 11,30V
Test Failed
Test6: P1=12V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=5,09V, P2=0,03V (L), P3=0,00V (L), P4=0,00V (L),P6=0,03V (L), P7=0,00V (L), P8=0,00V (L), P9=0,05V
P1(5,09V ) not in 11,70V - 12,30V
Test Failed
Test7: P1=13V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=0V
Result: P1=5,93V, P2=0,02V (L), P3=0,00V (L), P4=0,00V (L),P6=0,02V (L), P7=0,00V (L), P8=0,00V (L), P9=0,03V
P1(5,93V ) not in 12,70V - 13,30V
Test Failed
Test20: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=5V
Result: P1=0,00V, P2=3,75V (L), P3=0,00V (L), P4=0,00V (L),P6=3,74V (L), P7=0,00V (L), P8=0,00V (L), P9=7,19V
P9(7,19V ) not in 4,40V - 5,25V
Test Failed
Test21: P1=0V, P2=L, P3=L, P4=L, P6=L, P7=L, P8=L, P9=5V
Result: P1=0,00V, P2=0,05V (L), P3=0,00V (L), P4=0,00V (L),P6=0,05V (L), P7=0,00V (L), P8=0,00V (L), P9=7,17V
P9(7,17V ) not in 4,40V - 5,25V
Test Failed
Test22: P1=0V, P2=H, P3=H, P4=H, P6=H, P7=H, P8=H, P9=5V
Result: P1=0,00V, P2=4,90V (H), P3=4,91V (H), P4=4,93V (H),P6=4,88V (H), P7=4,93V (H), P8=4,90V (H), P9=7,14V
P9(7,14V ) not in 4,40V - 5,25V
Test Failed
3.3V Tests. Open J1 and press a key to continue
Test40: P1=0V, P2=Z, P3=Z, P4=Z, P6=Z, P7=Z, P8=Z, P9=3.3V
Result: P1=0,00V, P2=3,01V (H), P3=0,00V (H), P4=0,00V (H),P6=3,00V (H), P7=0,00V (H), P8=0,00V (H), P9=4,90V
P9(4,90V ) not in 3,00V - 3,70V
Test Failed
Test41: P1=0V, P2=L, P3=L, P4=L, P6=L, P7=L, P8=L, P9=3.3V
Result: P1=0,00V, P2=0,03V (L), P3=0,00V (L), P4=0,00V (L),P6=0,03V (L), P7=0,00V (L), P8=0,00V (L), P9=4,88V
P9(4,88V ) not in 3,00V - 3,70V
Test Failed
Test42: P1=0V, P2=H, P3=H, P4=H, P6=H, P7=H, P8=H, P9=3.3V
Result: P1=0,00V, P2=3,58V (H), P3=3,58V (H), P4=3,58V (H),P6=3,56V (H), P7=3,59V (H), P8=3,56V (H), P9=4,88V
Test Failed
Test60
95EA82392ECF233C
Test Passed
13 Tests failed
I thing it can be voltage regulator, but i don`t know the symbols.
Greetings,
The chip in the SOIC8 case next to the throttle is the MC34063. It generates a voltage of 8V to 13V.
I have this photos. Can it be helpfull?
Something else:Carprog2.jpgconnection_of_JTAG_Wiggler.jpg
Do you know what is UPA programmer ????
I don't think so.
I repent, a sinner, turned on the stupid in full, do not order the execution. Having froze today all brains in the fresh air, I foolishly laid out photos of Carprog. Worthy of universal censure and stupid cap.
I can take pictures of my Upa Usb only next week, for now, here are pictures from the Internet, maybe at least something can be seen on them ...1-android-in-dash-navigation-SC7265_01.jpgshit-upa-vs-goode-upa.jpgcn_ver1_2_.jpg
On Sunday I will be at home and I can take Upausb and take a photo from all angles. Still need?
