Buy a new FIS display, they're not expensive
Hi mates,
I´m triying to fix the central display on this dash and it is my firts time. I tried to find display but no good luck and match donor one but it has the same problem. I think is very common.
Can anyone help how to do it?
Thanks in advance
alclot (15th November, 2018)
This one I cant find on internet
Huh? Ebay is full of 1J0920826B clusters ?!
I bought one but same problem with central display. It light a lot then you can’t see fine the digits.
you try to change rubber conductor?i have same dash before one mont ago and i sucess to repair with another rubber conductor.
alclot (16th November, 2018)
Hello mates
Any ideas for repairing this dash?
Thanks in advance
alclot (9th July, 2019)
what problem do you have?
Hi mate. The problem is the display is with a lot of light. It is like all display on with a lot of intesity. I know problem is dump of dash but I´ve never repaired it. Perharps we need to find good dump from same reference right?
If you change to donor then it gets the same problem.
Thanks in advance
McDowell (9th July, 2019)
Any idea?
post ori dump here
alclot (29th May, 2019)
post part number.
It's a Motometer cluster- you will not find a replacement LCD for this type of cluster. The best way is to find VDO cluster 1J0920826C (TDI/ 260 km/h) and make adaptation- it's a 5 minutes of work. For VDO clusters you will have replacement LCD (big or small -depends of cluster type) but for Motometer no replacements.
VeryFastSnail (30th May, 2019)
The display gets worts when is hot. If I change the display the problem is the same. I dont what to do here. Please help.
