comizelu (17th November, 2018)
Let’s see results I got loads of vx to do that they claim will read pin over 30 so should see quite quick .
I couldn't find insignia..
I found mokka 2008- with same bcm eep.
Loaded the insignia bcm eep 24c16 and tango accepted it. Seen 2 keys and has option for pin as well.
But... To add key to insignia will it work under mokka? Remote as well? Any idea?
Inviato dal mio HTC 10 evo utilizzando Tapatalk
24c16 or 95160 have same file structure, it dosent matter which option you choose. 24c32 from newer Insignia do via Chevrolet camaro.
Yeah I just checked the truecode website great price and coverage if you already have the cable as that’s £350 but it’s between smok and truecode? I have avdi and the vehicle coverage seem very good but I don’t have the licences @€1100
Also will truecode read and display pin or not can anyone confirm?
Any thoughts?
Yes before programming it revel pin code and key code and tells you how many keys are programmed.
Galee (19th November, 2018)
Thank you for confirming
I have tdb1000 with opel sw
Astra h-pin cod and key programming for 5 min
They say to program nearly all the opel 2000-2019
