dtc codes MED9.1 2.0tfsi
Results 1 to 3 of 3
    May 2018
    sweden
    Default dtc codes MED9.1 2.0tfsi
    i want to remove
    P2181
    P000A
    car works perfectly.
    chain/timing is replaced and center with original tools. same codes persist.
    thank you for your help.
    May 2016
    Your file dtc off..No cs.
    Apr 2017
    I donīt recommend to disable P000A...
    There is something wrong with your intake camshaft or one of the three seals is faulty.... 100%
    To center with original tool, there are two positions to set it... One of them is wrong!!!!!
