Ford Galaxy SID206 DPF OFF
Results 1 to 5 of 5
    Sep 2010
    Slovakia
    Default Ford Galaxy SID206 DPF OFF
    Hello guys. Can someone help me with CORRECT DPF OFF solution for SID206? Thanks for help
    Jan 2018
    eeprom
    Try this solution and report if everything all right is?
  3. The Following User Says Thank You to atomantmk For This Useful Post:
    mati-rk (18th November, 2018)
    Team dz's Avatar
    Apr 2017
    ALGERIA
    here dpf = 0
    DPF / FAP / EGR / SCR / NOx / TVA FLAP .. etc
    Do not forget to press the button thanks and reputation
    # Algerian #
  5. The Following 3 Users Say Thank You to Team dz For This Useful Post:
    immokill (17th November, 2018), jovanzac (28th December, 2018), mati-rk (18th November, 2018)
  6. #4
    Sep 2010
    Slovakia
    Thank you for help atomantmk, but i also have this solution. ADS remover does the same file as yours and customer told me that it has sometimes white smoke, so i assume that it is stil regenerating. But can somebody please explain me what are the maps edited in front of that file? There are edited two 16x1 maps. In monday i will try to see measured values and we will see.
    Sep 2010
    Slovakia
    Quote Originally Posted by Team dz View Post
    here dpf = 0
    Thank you. I will test file at monday and let you know. But i see that there are also faults from DPF and also EGR ignored but i want to leave EGR functional.
