Hello everyone here thanks for helping us i learn alot from you
today i decided to remap my car DDE removing EGR and DPF from DDE map.
I have this software that can remove it from map but the problem after i finish modification
there is message about Checksum it is in the following photos
So please can you help explain that what is checksum is it necessary to correct it or i go now and flash my DDE with the new flash without any problem
Attached
DDE maps
The ORiginal named EDC16CP35
The modified named DPF+lamada
Flash file was Pulled by MPPS
My car DDE
jaberheraz (17th November, 2018)
Maybe a silly question...
You have a diesel....(?)
You wrote that it's a Edc16....(?)
And you removed DPF.... That's clear...
And then you removed.... LAMBDA....?
is this right...?
When I helped you press Thanks and Reputation...
jaberheraz (17th November, 2018), luckerr (23rd January, 2019)
thanks brother i will flash it to the car now and report updates
I Upload the flash file to the car success flashing
thanks vagva
