Results 1 to 2 of 2
    May 2010
    Default 2010 Nissan Sentra - Bcm Locked
    This car bcm has being locked that if even you type the correct pincode, it says key programming failed. Many attempt was carried out before car came to me.
    i want to know if there is a way to reset the bcm so that this failed message can be corrected.
    Things done so far-:
    removed battery termainal for overnight but did not work out, turn key on for 1 also did not work out, which other way again please. Or does it means need to get new bcm
    Aug 2012
    Hi ,
    You solve the problem ?
    I have this same problem with Nissan Pulsar 2013.
    Some one erase the all key try to add othe many times and BCM was lock.
