Results 1 to 4 of 4
    Nov 2017
    Default Audi Symphony AUZ5Z4 poweron the bench
    Audi Symphony AUZ5Z4 4B0035195
    Radio worked in car and was blocked after disconnect
    I try powering it on the bench
    I see power consumption when press Power, and consumption off when power off
    But nothing on lcd
    Does this model must normally power without car?
    Thanx
    Nov 2010
    Yes. Should work without a car.
    Nov 2010
    Check the connection of the panel to the main Board.
    The connection may be broken when removing the radio
  4. The Following User Says Thank You to simplus For This Useful Post:
    SVH (20th November, 2018)
    Nov 2017
    It was hardware problem,now radio works
    One more question:
    before entering code radio shows: 1000 I
    I-means:
    1. it will be first attempt?
    2. code allready entered one time?
    3. one attempt left?
