Results 1 to 5 of 5
    May 2018
    Default Chevy Malibu 2008
    Hi to all I have Malibu after edit km with dp4 by obd2 radio locked old changed all ok but after change odo not move I drive with it 50 km not work 120000 freez any one have bcm open to put recovery file because it is closed . Thx
    Sent from my SM-G611F using Tapatalk
    epd1221's Avatar
    Nov 2011
    usa
    Try doing again and if dosent change , read eeprom and post it here .. I had a similar problem and I fix it wi th jprog .. And about radio autel scanner can unlocked it easy
    May 2018
    Quote Originally Posted by epd1221 View Post
    Hi friene proplem is how to open bcm to read it is very hard open
    U.S.A
    drill metal nut on the back...in the middle of the plug
    Oct 2017
    california
    use Gm Tis2web and flash the bcm
    no need to disassemble it
