Results 1 to 4 of 4
    melcool's Avatar
    SPACE
    Default Touch & Connect Corsa D Code Reset pls
    Please help with code and reset ... unit is locked
    MC Corsa EU Matt Chrome F250
    7 612 830 110
    GM 13 362 756
    UFZ NA
    SW date 17.11.2010
    HW date 01.07.2011
    Many Thanks in advance!
  2. The Following User Says Thank You to melcool For This Useful Post:
    Thinner (18th November, 2018)
  3. #2
    Jupiter199's Avatar
    Feb 2016
    Code is 9239
  4. The Following 6 Users Say Thank You to Jupiter199 For This Useful Post:
    ilen (17th November, 2018), masterskay62 (17th November, 2018), melcool (18th November, 2018), sanixmen (17th November, 2018), smoggy (18th November, 2018), Thinner (17th November, 2018)
  5. #3
    melcool's Avatar
    SPACE
    Thank you for the code... but how to enter it because over the code enter menu it appears unit locked(from previous code atempts)...
    Trimis de pe al meu SM-G955F folosind Tapatalk
  6. #4
    melcool's Avatar
    SPACE
    Jupiter199 code is correct...THX... and maybe also your erase/reset solution is OK...BUT I have used Thinner pached file to write back on sectors 264 - 415 and now the Touch & Connect is working again
    Thank you all!
    Reputation added for both of you!
  7. The Following User Says Thank You to melcool For This Useful Post:
    Thinner (20th November, 2018)
