Best to back to stock with winkfp, then read file with mpps, modify, and write back
EDIT : ECU Readout on post #8 in this Thread - I GOT IT Yippie
Hello everybody
I´m new here, My Name is Joachim, im from Europe
I´m 33 Years old and have some Interests in ECU Programming.
I´m fit with Siemens MS42 and MS43.
For 5 Weeks i bought my first BMW Diesel, its a E60, 530D, from June/2006, Engine Typ: M57N2, with Bosch EDC16CP35.
I Have the option (with Original Equipment) To flash every ZUSB on this ECU.
I Have some Questions, before i ask somebody to remap some things for me.
I dont want to touch a EDC ECU ! (With Siemens i have no Problems)
My car, surelyyyyyy, has a Particel Filter (DPF) Installed, I Kicked the Partikel Filter Part out of the Assembly, and only leave the Catalytic converter in it.
I Have two Original Specific Options i can write to the DDE.
- The Original one, with DPF -> The engine has excessive Power !, but of course about 10 km driven, it goes to "Limp Mode" (Without any Check engine Light)
Error Memory: Particel Filter Pressure, and Filtersystem not Present. .
This Software turns on Check engine light after Ignition is switched on- and goes off when the engine is starting.
- Then Exists a orginal Software from BMW: Option SA169, Exhaust specification EU3, where instead of the Particle Filter only a Catalytic converter is Present (This Software i´m Currently drivin)
Error Free, DPF Is here already "off". BUT: check Engine light is NOT illuminating at ignition on.
AND The engine , i feel so, hasn´t the Power as with the DPF Software.
But i need for the yearly Technical Check by our laws here, that this light shows up at ignition on ! (And go off after engine start)
About the EGR/AGR: I switch to +80mg Air / Hub with Toolset32, No Problems with it.
A Question to all Tuners here:
What would you do ?
- Tune my DPF-OFF (EU3) File and switch the Check engine light on, on ignition ?
OR
- Tune my original DPF File, and switch here the DPF off ?
Have MPPS V16, to read it out.
( I read about some Problems with it, but i think, its, because People select the wrong ECU before REWRITE it.)
EDC16CP35 readout should be 2MB or 1MB ? (EDC16C31 was 1 MB or ??)
I Must look to MPPS for myself which ECU i must select, i get MPPS this week...
AND:
Is everyone here so free, and can do this Changes for me ?
Had Coded the Car already to +SA169, so the "Particle Filter" is Removed from the CBS (Service in the idrive Display)
Many Greetings
Joachim
Edit: Will Upload an Original File WITH DPF, this Week (Wait for MPPS).
Help for DPF OFF and a Remap to more Power/Torque (Original is 231HP / 500NM Torque) is welcome / Car has a manual Tranny
Any Safety Things (Temperature, RPM Limiter, Speed Limiter etc...) Same as AGR/EGR: Please Leave Original as is.
Will write a reply Posting with the File then .
Hi, Thanks for your response
Okay i will do so.
Do you know, if i Rewrite the modified File then with MPPS - Fails, i can reprogramm it without Troubles with Winkfp (I have all SP Daten , this is no Problem for me? Or is the ECU Totally bricked and on the diagnosis Bus "Offline"- when a remap with mpps fails (Write error for example ...)
Greetings
Have a nice week
here take a look at this thread...
http://www.digital-kaos.co.uk/forums...eeded-EDC16C31
he uses telwin... a 500€ power supplier and X17 a 5500€ tool.... and it went bad...
it´s easy to open this ecu and with bdm reader you´ll be much more safer...
but yes, it´s possible to do it over OBD...
and if you´ll be able to recover it by winkfp depends if ecu is responsing or not...
When i helped you press Thanks and Reputation...
Grüsse aus Hessen...
Hihi.
Okay thanks.
On the Siemens MS42/MS43, i know (Tested) If a MPPS or Galetto Flash - FAILS, it EVER can be recovered with winkfp.
I Think the Basic OS on this ECUs is never touched.
I Dont know how this on EDC is.
Hm... Bosch ... Better forget it... *looooooooooooool*
We will see, i wait for my mpps now, and look that i can do a readout.
Don't worry so much on this EDC16
it's always working with every tool
Hello.
Today MPPS is here
I found in ECU List 2 Options.
530 3.0D Bosch EDC16C35 K_Line_Fast/CAN
or
530 3.0D Bosch EDC16C35 K_Line_Slow/CAN
I Think "Data only" (Partial Read) is enough or ? Is a Full readout needed ?
Which of this 2 Options shall i choose for Reading/Writing ?
On both Options MPPS says as Info: 14V Or above are recommended. (14 V Is a Voltage, that only is Present when the car is running and supplied by the generator ???)
Is it Okay, when i Plugin a Batterycharger while readout ? (Battery is new, My Car is generally fully serviced by me)
Greetings
Hey.
Here is my Readout with MPPS V16.
Engine Type: M57N2, 170 KW, 231 HP.
BMW E60, Manual Transmission from June/2006
ECU : Bosch EDC16CP35
File : 2 MB.
Original BMW, Factory ZUSB: 7811719
Please be so kind and do following for me:
- Check File integrity. (If MPPS Reads it correctly)
- Disable DPF System and switch DPF-DTC´s to off and Zero the Regeneration Map. (I Think it doesn´t need to richen the Mixture ....)
- Do it a little Remap to more Power and Torque. But please don´t kill my Engine- ITS NOT A RACE CAR ! I Trust you !
(I love the Torque of the engine--- can easy climb a Hill on the 6th Gear on 1400 rpm...)
Thanks in Advance .
here you go mate DPF OFF ... pass PM
(\__/)
(='.'=) This is Bunny. Copy and paste bunny into your
(")_(") signature to help him gain world domination.
Mindvision (22nd November, 2018)
Thank you for your Fast Work !.
Please look @ PN
Greetings
Hi Gad3n
Your Inbox (Private Messages) is full
I want to report you something .
Cheers;
Joachim
i cleared some space
(\__/)
Mindvision (23rd November, 2018)
hey could i get a password too iwould like to see the changes that have been done to the dpf.
Upload your own file! And before help other because you didnt got permission to download before ;D
