Page 1 of 3 123 LastLast
Results 1 to 15 of 34
    Default W203 EZS and BE keys
    Hi mates!
    I programmed a BE key for W203 with HC908 EZS and I've got some problems. During driving the car, the consumers are powering off, the suction fan is working at max RPM and the faults:
    B1025 The input signal 'circuit 15' is not o.k.
    B1032 The input signal 'circuit 15R' is not o.k.
    are recording on SAM-F control unit. I tried many EZS(2035450108, 2035450308, 2035450508) but always I have the same problem. The original keys seem to work good.
    Is there any known compatibility issue between HC908 based EZS and BE china keys? I tried the VVDI keys and 2 batteries keys, always the same problem...
    Best Regards
    Nov 2018
    GB
    Hello friend
    provide EIS dump, did you try NEC key version 51?
    Quote Originally Posted by khoulioking View Post
    Hello friend
    The original keys seems to working fine.
    pepi's Avatar
    Program used keys, BE keys not working well on this EZS.
  5. The Following User Says Thank You to pepi For This Useful Post:
    papalos_ (23rd November, 2018)
    ASCM's Avatar
    Oct 2018
    be key work perfect in this eis mcu version just quality of your be key its problem
  7. The Following User Says Thank You to ASCM For This Useful Post:
    dritan (23rd November, 2018)
  8. #6
    Nov 2018
    Brussels
    Try another key
    If I Help You Please Rep + Thanks ME
  9. The Following User Says Thank You to Bryanlocksmith For This Useful Post:
  10. #7
    p1et's Avatar
    Oct 2013
    As above, program original NEC key.
    Is your BE key from Xhorse?
  11. #8
    Quote Originally Posted by p1et View Post
    The one I programmed is from Xhorse and the other a two batteries BE key.
  12. #9
    p1et's Avatar
    Oct 2013
    So the next evidence that those xhorse keys are not 100% working (as been said) and I think none of BE keys will ever work 100%.
  13. The Following User Says Thank You to p1et For This Useful Post:
  14. #10
    Quote Originally Posted by ASCM View Post
    Can you provide me a link of good quality BE keys that are working flawlessly on those EZS?
  15. #11
    You mean that BE keys are not working 100% generally or on HC908 based EZS?
  16. #12
    p1et's Avatar
    Oct 2013
    Quote Originally Posted by papalos_ View Post
    I'm just saying you are the next person who proved that Xhorse BE keys are not 100% compatible with all types of EIS as it's being advertised.
  17. The Following User Says Thank You to p1et For This Useful Post:
  18. #13
    pepi's Avatar
    I have try also with xhorse key and it was the same think. At w203 with HC08 I use used MB keys.
  19. The Following 2 Users Say Thank You to pepi For This Useful Post:
    p1et (23rd November, 2018), papalos_ (23rd November, 2018)
  20. #14
    i have used BE keys from xhorse and others and all work the same.
    some fail and some work.
    but at the end i get them all to work oke!
  21. #15
    Quote Originally Posted by vageric View Post
    ... but at the end i get them all to work oke!
    Could you be more specific please?
