I have a eagle sattelite receiver with a broadband connection how do i insert a cccamcfg code
hi
may i know what the diff with this ... ?
the services file doesn't have an extention
AND
With enigma, each bouquet you create has it's own userbouquet file.
userbouquet.*****.tv - /var/tuxbox/config/enigma/cable
my brothers dreambox 500c lost most of its channels a couple of days ago. Only freeview were avaialble. Having spent nearly 2 days trying to figure out the problem, including doing a factoty reset, downloading lateset dk_v1.1.img (both manual and via ftp). I still only pick up freeview (no Sky sports etc.) If anyone as any fixes or info., I would be vey greatful.
what area are you in? if it's N3 - you're out of luck
problem solved
hi all ^^
i m new to this forum
i have flashed mydm 500c and now have nothing but blue screentried to upload new image still nothing any help plz
hi
i need to ask isit a must to create bouquets after i had edit the channel list??
no zapit folder any idea why not?
hope this is the right area to ask this, knowledge is the key as they say. any way what is the most uptodate files both image and bouquets.
thanks for any help you can offer.
I have dreamup to flash the dm500sg.img into the 500C successfully but I ma not able to view the encrypted channels. Anyone here can assist me?
I just setup an old DM7025 last night after finally installing the full satellite configuration. I have just 3 satellites 13, 19 & 28. This is setup with Enigma2
I have confiured the box for these satellites and then carried out a scan (including delete before scan).
The result is I see in the 'boutique' all satellites in existance (well looks like it). I want to remove all the 'unwanted' satellites.
I installed and setup dreamboxedit. Copied the files to my PC, selected one satelitte at a time and deleted al the channels from the listing of an unwanted satellite. I then loaded this back to the DB but I still see all these unwanted satellites.
I would appreciete any help. I guess I could work out which .XML holds this data and manually edit this, but wanted a safer way to do this. I did a quick search but could not see this answered therefore have joined here so I can post and join the community as a newbie which I hope will not be the case for long.
