Page 1 of 5 12345 LastLast
Results 1 to 15 of 65
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    Default Info: Dreambox Services and Bouquets
    When you do a transponder scan on your dreambox, automatic or manual, a services file is automatically generated with the frequencies and services ids of all the channels found. If you have successfully done a services scan and found all the channels, there's no need to copy over additional services files.
    So you've managed to get all your channels and set up your bouquets just the way you want them. The first thing you want to do is back them up to your PC for safe keeping. If you need to flash the image again, for whatever reason, it's always good to have the services and bouquets backed up, then you simply copy the files to the box instead of setting them up from scratch again. Neutrino and Enigma are different in the way they store the services and bouquets.
    Enigma
    With enigma images, the services file doesn't have an extention and is stored in the following location:
    services - /var/tuxbox/config/enigma
    With enigma, each bouquet you create has it's own userbouquet file. These files are stored in:
    userbouquet.*****.tv - /var/tuxbox/config/enigma/cable
    There's also a file called bouquets (without extention) in /var/tuxbox/config/enigma that you want to backup as well.
    So when you're backing them up to your PC you want to copy the 'services' and 'bouquets' files from ../enigma and all the 'userbouquet' files from ../enigma/cable folder.
    Once you've copied them back to your dreambox, use the browser reload commands below. They won't take effect unless they are reloaded.
    Some images may have a 'ReloadChannels' option, usually in the BLUE button menu or User Features menu, this can also be used to reload the channels.
    Neutrino
    With neutrino images, the file system is more like the dbox2.
    services.xml - /var/tuxbox/config/zapit
    ubouquets.xml - /var/tuxbox/config/zapit
    All your bouquets are stored in the ubouquet.xml file instead of an individual file in enigma.
    Same as above, you will need to reload the channels before they will take effect. On neutrino images, there's usually an option in the Services Menu to reload channels.
    Reloading Services and Bouquets after transferring (using Enigma/Gemini)
    Once you have transfered your backed up services and bouquets to /var/tuxbox/config/enigma, follow these instructions.
    To reload services...
    Open web browser and paste the following command into the address bar:
    http://192.168.xxx.xxx/cgi-bin/reloadSettings
    (replace x with your own ip address)
    To reload bouquets...
    http://192.168.xxx.xxx/cgi-bin/reloadUserBouquets
    If you're using the Digital Kaos image, you can also reload the channels using the 'ReloadChannels' option in the User Features menu.
  2. The Following User Says Thank You to Devilfish For This Useful Post:
    father ted (18th October, 2023)
  3. #2
    DK Veteran alliv's Avatar
    Jun 2008
    well done devilfish, a top class piece of info for all newbies and the likes of myself who forgets the location of theese files. this will help a lott. thanks m8.
    is it a bird?......is it a plane?.....NO ITS MY CHEAP CLONE FROM CHINA GOING OUT THE ~~~~ING WINDOW.
  4. The Following User Says Thank You to alliv For This Useful Post:
    basman2019 (2nd July, 2019)
  5. #3
    Member Booya16's Avatar
    Aug 2008
    East London
    Smile
    Agreed, well done.
    Was wondering how to reload settings without physically getting onto the box.
    Cheers again.
    Booya16
  6. #4
    Sep 2008
    Excellent Devilfish, as usual!
    I have a query.
    I just flashed a new image and run a scan of all the channels. They are not organised yet in bouquets.
    I found online services and bouquets files for my local area (Cheltenham) and would like to use these.
    Do i need to remove the ones currently on my 500c first?
    I also found more recent "services xml" files for my area on DK. Better to use these or am I getting confused (not difficult)?
    Cheers
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    If you have obtained a set of services and bouquets, put them on the box first and reload the channels (you can also reload channels by doing a 'restart enigma' from the shutdown menu). Now you have bouquets that are assigned to your services.
    Now do a fresh scan and it will add any channels you don't have to the current services file. These new channels will be in the 'All Services' menu and you can add them to bouquets if you want.
  8. #6
    Sep 2008
    Thank you Devilfish
    I'll try and do that straight away!
  9. #7
    Sep 2008
    Quote Originally Posted by Devilfish View Post
    Hi Devilfish
    I followed your excellent guide to the letter but, after ftp'ing the services and bouquets files for my local area (and reloading services and user bouquets), nothing appears to have changed in the box
    Any idea?
  10. #8
    Jun 2008
    Quote Originally Posted by vocalis View Post
    Hi Devilfish
    Any idea?
    did you restart the box?
  11. #9
    Sep 2008
    dreamboxedit is also useful way to backup and edit your services and bouquets plus it lets you reload by clicking a button.
    http://sourceforge.net/projects/dreamboxedit/
  12. #10
    Sep 2008
    Quote Originally Posted by alliv View Post
    Thanks alliv. Yes I did restart the box.
    Hi rajid187: I will try dreamboxedit.
    I just don't understand why it shouldn't work with the above.
  13. #11
    Sep 2008
    Default Using DreamEdit to generate bouquets
    I attempted to use DreamEdit
    (Digital Kaos - Downloads - DreamboxEdit v2.02) to install bouquets. I tried this several times without success. Your important instruction to "Copy all userbouquet files to /var/tuxbox/config/enigma/cable" solved the problem. The paths in the DreamEdit program for file transfer seem to be ok. However I found that the user Bouquet files in the cable directory were essentially empty. I examined these files in wordpad and they contained no information. Another set of user bouquet files were in the enigma folder. These did contain information. I used ftp to transfer these files to the cable folder and everything worked fine.
    Perhaps I should have started by deleting any existing bouquets using the dreambox editor before attempting to use the DreamEdit program.
    Thanks again.
  14. #12
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    Glad you're sorted and up and running!
  15. #13
    Nov 2008
    hi all i have a dreambox 500c i want to use for cable new to this how do i go about this step by step would help thanks
  16. #14
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    Start by reading the sticky thread in this section.
    Give them a try and if you get stuck, let us know.
  17. #15
    Nov 2008
    thank for help will do
  18. The Following User Says Thank You to monty11 For This Useful Post:
    radioham2000 (14th October, 2013)
