Page 3 of 5 FirstFirst 12345 LastLast
Results 31 to 45 of 66
Thread: carsoft mb&bmw
  1. #31
    Default thanks
    thanks! for sharing this
  2. #32
    Top Poster don007's Avatar
    Question carsoft fault codes
    hi am after carsoft fault codes in pdf or p-codes to DDE5 anyone here can help plz
  3. #33
    Sep 2010
    Thank you for sharing
  4. #34
    Sep 2010
    hello i have dreambox 500c plz tell me ho to recode
  5. #35
    It is possible to install on xp with service pack 3?.Because i recieve error:either the source or destination must have a master disk.Any ideas?
  6. #36
    Jun 2009
    Default MB Carsoft 7.4
    Quote Originally Posted by Claudiu_dar View Post
    Try this my friend and if it was usefull don't forget to hit the "thanks" button.
    Anyone have for sharing MB Carsoft 7.4 german version.Thank you.
    Regards,
    Danilo
  7. #37
    DK Veteran manocao's Avatar
    this carsoft mb version says to work with kkl vag-com interface
    http://rapidshare.com/files/54659345...08_CRACKED.rar
    of course, for models up to june 2004
    can anyone try and confirm?
    for more versions (german etc) search carsoft in FileCrop - Search and Download Rapidshare and Megaupload Files
  8. #38
    DK Veteran tapiru's Avatar
    Quote Originally Posted by manocao View Post
    Hello Manocao
    Did you know it is needed an comport KKL cable or an USB KKL cable?
    Thanks!!!!
  9. #39
    i think it doesnt matter if it is rs232 or usb
    inside the rar file, it says "any PC-to-K-line adapter cable (for example this http://www.autoelectric.ru/diagnosti...l-line-v21.htm)"
    the interface of the example is rs232, but i think any iso-9141 interface will do the job
  10. The Following User Says Thank You to manocao For This Useful Post:
    Col19 (24th November, 2020)
  11. #40
    hi m8,
    does it need other modifications on the kkl cable like for BMW?
    big thanks!
  12. #41
    dont know, i think it doesnt
    i'll try on c220 w203 my2004 asap and tell
  13. #42
    that will be very helpfull as I have a c200 w203 and want to find out,
    thanks manocao!
  14. #43
    Sep 2010
    With a modified for BMW KKL cable, program does not work with ML270CDI (W163). Tomorrow I will try with unmodified KKL adapter and write what is the result.
  15. The Following User Says Thank You to kaci For This Useful Post:
  16. #44
    Quote Originally Posted by egyclick View Post
    hi m8,
    big thanks!
    Hello m8
    Excuse me for my stupid question but what kind of modification is needed on kkl cable for running BMW CS 6.5 ?
  17. #45
    Quote Originally Posted by tapiru View Post
    Hello m8
    I never used carsoft with my modified kkl but instead it works with Inpa 5.0.2, Dis 57, SSS 32...
    the modification involves soldering together the 2 pins 7 & 8 inside your kkl and after that you need to invert RI # and DSR # signals to fool the detection of battery and ignition
    it is better explained here: http://www.digital-kaos.co.uk/forums...-proof-161771/
