Page 4 of 5 FirstFirst 12345 LastLast
Results 46 to 60 of 66
Thread: carsoft mb&bmw
  1. #46
    Sep 2010
    Today as promised I tried to connect with unmodified KKL adapter with the same car and the result is NEGATIVE. Cable has been tested and works well with FiatECUScan. For me this program unfortunately does not work!
  2. #47
    Quote Originally Posted by kaci View Post
    thank you for the info, maybe someone who did it can give us a clue on what it needs to be modified
  3. #48
    DK Veteran manocao's Avatar
    this is the version you tried?
    http://rapidshare.com/files/54659345...08_CRACKED.rar
    this is what carsoft mb 7.4 is supposed to support:
    ALL BRAKE SYSTEMS (ABS/ASR/ETS/ESP) till 06/2004
    Read & Erase all Faults Codes
    Detailed Repair Information
    ECU Information
    ESP LIVE DATA
    ABS2 ACTIVATION '95 onwards
    ALL AIRBAG SYSTEMS till 06/2004
    ECU Information
    ECU CODING
    PARAMETER SETTING
    ALL INSTRUMENT CLUSTERS (KI) till 06/2004
    ECU Information
    ALL BRAKE ASSISTANCE (BAS) SYSTEMS till 06/2004
    ECU Information
    ALL GEARBOX (EGS) SYSTEMS till 06/2004
    ECU Information
    LIVE DATA
    ADAPTATION
    ALL KEYLESS GO SYSTEMS till 06/2004
    ECU Information
    ALL SERVICE INTERVAL SYSTEMS till 06/2004
    ECU Information
    SERVICE RESET
    SERVICE PROGRAMMING
    ALL AIR SUSPENSION (AIRMATIC) SYSTEMS till 06/2004
    ECU Information
    LIVE DATA
    ACTIVATION
    ALL ACTIVE BODYCONTROL (ABC) SYSTEMS till 06/2004
    ECU Information
    ALL PNEUMATIC (PSE) SYSTEMS till 06/2004
    ECU Information
    ALL PARKTRONIC (PTS) SYSTEMS till 06/2004
    ECU Information
    LIVE DATA
    ALL ACTIVITY (AAM) SYSTEMS till 06/2004
    ECU Information
    ECU CODING
    ALL EXTENDED ACTIVITY (EAM) SYSTEMS till 06/2004
    ECU Information
    ECU CODING
    ALL COMMAND (D2B) SYSTEMS till 06/2004
    ECU Information
    ECU CODING
    ALL ANTI THEFT ALARM (ATA / DAS) SYSTEMS till 06/2004
    ECU Information
    ALL ELECTRONIC IGNITION (EIS) SYSTEMS till 06/2004
    ECU Information
    ALL UPPER CONTROL PANEL (UCP) SYSTEMS till 06/2004
    ECU Information
    ALL LOWER CONTROL PANEL (LCP) SYSTEMS till 06/2004
    ECU Information
    ALL OVERHEAD CONTROL PANEL (OCP) SYSTEMS till 06/2004
    ECU Information
    ALL XENON LIGHT (HRA) SYSTEMS till 06/2004
    ECU Information
    LIVE DATA
    ACTIVATION
    ALL CONVERTIBLE TOP (RVS/VD) SYSTEMS till 06/2004
    ECU Information
    ALL SIGNAL ACQUISITION (SAM) SYSTEMS till 06/2004
    ECU Information
    ALL DOOR CONTROL (DCM) SYSTEMS till 06/2004
    ECU Information
    ALL ELECTRICAL SEAT (ESA) SYSTEMS till 06/2004
    ECU Information
    ALL CENTRAL GATEWAY (CGW) SYSTEMS till 06/2004
    ECU Information
    ALL AUTOMATIC CLUTCH (ACS) SYSTEMS till 06/2004
    ECU Information
    ADAPTATION
    Bleeding of the CLUTCH
    ALL ELECTRONIC SELECTOR (ESM) SYSTEMS till 06/2004
    ECU Information
    ALL SPRINTSCHIFT (SSGM) SYSTEMS till 06/2004
    ECU Information
    ALL DIAGNOSTIC (DM) MODULES (USA) till 06/2004
    ECU Information
    Main functions
    Petrol Engines ALL ENGINE - TYPES till 06/2004
    ECU Information
    ME CODING
    HFM CODING
    ME ADAPTATION
    HFM ADAPTATION
    LH ADAPTATION
    ME LIVE DATA
    HFM LIVE DATA
    Diesel Engines ALL ENGINE - TYPES till 06/2004
    ECU Information
    CDI LIVE DATA - STREAM
    CDI INJECTOR TEST
  4. The Following User Says Thank You to manocao For This Useful Post:
    Col19 (17th November, 2019)
  5. #49
    H? Manocao , this version 7.4 is better than 7.6 + service pack 1 ?
    Which is better ?
    Thanks.
  6. #50
    anyone up to now
    still havent found some working version for kkl
    i tried yesterday on c220 with 7.4sp1 and 7.6sp1
    it was bmw modified interface
    i also tried the version kaci tried, and also this one which has different exe files also reporting to work with kkl:
    http://www.rapidshare.com/files/1369...oft_mb_7.4.rar
    please kaci try on your car
  7. #51
    Sep 2010
    Ok. Next week I will try with different versions of the program and with different settings for USB port. I'll write about what happened. I hope together to achieve success! I attach version, which I think is most likely to succeed.
  8. The Following 2 Users Say Thank You to kaci For This Useful Post:
    Col19 (17th November, 2019), Hollowman1701 (24th May, 2020)
  9. #52
    DK Veteran tapiru's Avatar
    Excuse my ignorance but how can be install this sw.
    After unpack lots of DTX files and no setup or installer.
    Please advice.
    Thanks!!!!!!!
  10. #53
    Sep 2010
    Quote Originally Posted by tapiru View Post
    Please advice.
    Thanks!!!!!!!
    This version is not installed. Just unpack the file and run with Carsoft.7.6.kl (application). I have installed another version and that starts without a problem. Unfortunately not work (yet).
  11. The Following User Says Thank You to kaci For This Useful Post:
    Col19 (24th November, 2020)
  12. #54
    this is carsoft mb 3.0 for dos (english version)
    it works with windows xp, so it supports usb interfaces (in com1)
    i know it is old, could someone try with kkl vag interface?
    run start.exe to start the program
    http://www.digital-kaos.co.uk/forums...start.exe-.rar
  13. #55
    Belfast, NI
    Anyone ever manage to get the MB carsoft working on k-line device?? Even 3.0?
  14. #56
    May 2011
    thx its works without problems
  15. #57
    May 2011
    sarajevo
    Default Hellp
    hellp with vcds 908
  16. #58
    Jun 2009
    Porto
    and????
  17. #59
    Oct 2017
    Has anyone yet discovered that using hacked Carsoft resulted in acquiring malware ?
  18. #60
    Dec 2018
    Quote Originally Posted by Claudiu_dar View Post
    Try this my friend and if it was usefull don't forget to hit the "thanks" button.
    Are these files still available?
