Results 1 to 10 of 10
    Jan 2019
    GB
    Default I need flash file for BMW E60 2004 61.35- 6943791
    Hi, I need a flash for a BMW E60 (2004) CAS2 61.35- 6943791
    The flash may be corrupted, there's no ignition.
    Thanks in advance!
    May 2010
    Bulgaria
    Here you go
  3. The Following User Says Thank You to karalada For This Useful Post:
    meteovlora (18th July, 2022)
    Jan 2019
    GB
    Post Going to try it
    Hi, thanks gonna try it right now.
    Btw can someone take a look at the eeprom file and tell me if it's everything ok?
    Jan 2019
    GB
    Post Eeprom
    Not working. Starting to think I'll need to recover all the data stored in the eeprom. I can't match up/link DDM with CAS. If anyone can take a look at the file I attached before or provide me with a working eepro.
    Thanks all in advance!
  6. #5
    Jan 2019
    GB
    help me can someone
  7. #6
    Jan 2010
    uk
    writing eeprom file from other car wont start your car as it holds unique key data also other info..
  8. #7
    Jan 2019
    GB
    me puede ayuda alguien
  9. #8
    Feb 2017
    Baltic
    yes if eep from another car change vin and it s checksum, make keys, sync ecu etc, not hard if you have tools.
  10. #9
    Jan 2019
    GB
    no tengo heramientas para recuperar la eepro de la cas2
  11. #10
    Jan 2019
    GB
    Default eeprom cas2 corupted
    adjunto lectura eeprom cas2, la podeis revisar por mi
