Page 13 of 15 FirstFirst ... 389101112131415 LastLast
Results 181 to 195 of 218
  1. #181
    Sep 2011
    Default TM5300D+ question
    Quote Originally Posted by .: JaCkPoT :. View Post
    Guide for the newbies.
    Heres how to load the patches.
    • Download the relevant patch and extract.
    • Download the relevant loader and extract.
    • Connect your receiver to the pc via rs232c cable.
    • Choose the correct com port.
    • Leave the receiver on standby.
    • Open the loader and select the software tab.
    • Press browse and find the extracted patch.
    • Press ok then start then wait.
    This will take a few minutes. Thats it. The same things need doing for softcams but make sure you use the keys tab. Everything else is the same.
    USB, By Benny/9
    FIRST ALWAYS MAKE SURE YOU USE THE CORRECT PATCH FOR YOUR MODEL
    there are various models and only the correct patch will work or even load on your model
    • Download the correct patch for your receiver.
    • Open the zipped folder and take the patch out ready to transfer the patch onto your usb memory stick.
    • Insert your usb memory stick in the usb port under the front flap.
    • Turn the receiver on ready to load the patch then press the usb button on your remote.
    • on the next screen go to data transfer and click>OK.
    now you will see a panel with the patch on it, it will highlight, [for patching].
    press ok on the highlighted patch then it will load and when it gets to 100% and has loaded, and the receiver has re-booted [turned off and on again] and the channel opens, remove your usb memory stick. you have now loaded the patch and your channels will now open.
    you also load softcams/channel lists/official software etc:in exactly the same way by selecting
    the item you want to load.
    Note: if scrambled channel appears on channels which should open; wait a few minutes. This will enable the auto update to kick in.
    Hope this is found helpful. Sadiq999uk and Benny/9
    Thanks for this Benny,
    I found this really useful.
    Just a quick quesiton. I have a TM 5300 D+ Super
    So do I simply go look under the section "TM5000 series patches" and look for the one with the most recent date on it?
    Mine has USB on it. So I can I use a stick for this.
    Should I first update the software with the latest from the TM manufacturers site before using the patches found in this forum?
  2. #182
    i have technomate tm-600,can i watch romanian channels ,1 year ago i watch digi tv ,after move to nagra 3,please help.sorry for my english.
  3. #183
    Oct 2011
    Default TM5200d functionality
    There is a usb port for this model but what does it do? Can I get more channels? Will it show movies from a usb in mpeg2 format as well as jpegs and mp3s?
  4. #184
    Jun 2009
    you must ask questions in the normal technomate thread section you will not get answers here as very few check this section out.
  5. #185
    Dec 2011
    I just bought a Technomate 300D and i can't watch any channel on my tv! Almost all of them are bloked. It seems that i have to pay to watch them! The satellite is Hispasat.I have to install any kind of patch to watch TV?
    Thank you
  6. #186
    Oct 2011
    Hi. The HISPASAT sat at 30 west has very few channels opened at this moment because all the good channels use Nagra3 which has not been broken yet. You are probably better off to get a motor and move the dish to other satellites where you will be able to find much more channels. What are you looking for in particular?? Also what size dish do you have and where are you located??
    Regards.
  7. #187
    Dec 2011
    Hi.
    Triax TD 78 this is my dish. My receiver is a Technomate 3000D. The guy came to my place and installed everything.I live in Luton UK. i really want that satellite cose i want to watch portuguese tv
    thank you
  8. #188
    Oct 2011
    Hi. I only know 2 Portuguese channels on HOTBIRD which are available for your receiver ie RTPI and TV GLOBO. You can ask in this forum if channels on HISPASAT are available but its probably best to start new thread in the TM section. Regards.
  9. #189
    Dec 2011
    Thanks for your help. I really want that satellite cose i want to watch football and in those 2 channels im not abble to do it
    thank you
  10. #190
    Oct 2011
    Hi. RTPI show live Portuguese matches and GLOBO show live Brazilian football. Which football are you interested in? Regards.
  11. #191
    Dec 2011
    Technomate TM 5402 HD Super CI USB PVR LAN SAT Receiver
    Do I have to update oem firmware first before flashing custom img ?
    Great site plenty of support...love it
    benjy
  12. #192
    Dec 2011
    Hi. is only 2 channels. on Hispasat i can have all of them but i don understand why they are bloked!
    Do i have to do some upgrade on my receiver?
    I read here something about a patch. but i dont really know what that means!
    Once again thank you
  13. #193
    Oct 2008
    Quote Originally Posted by monforte76 View Post
    All the channels that you want to watch are encrypted in nagravision 3, this encryption system has not been hacked
    So you will have to either buy a legitimate subscription or go the card share route(we cant talk about c/s on here) so google it
    Regards Mikiemo.
  14. #194
  15. #195
    No sorry..........
