Page 1 of 15 12345611 ... LastLast
Results 1 to 15 of 218
    Retired Sat TV Addict
    .: JaCkPoT :.'s Avatar
    Aug 2008
    var/tuxbox/plugins
    Default Noobs guide to patching your Technomate
    Guide for the newbies.
    Heres how to load the patches.
    • Download the relevant patch and extract.
    • Download the relevant loader and extract.
    • Connect your receiver to the pc via rs232c cable.
    • Choose the correct com port.
    • Leave the receiver on standby.
    • Open the loader and select the software tab.
    • Press browse and find the extracted patch.
    • Press ok then start then wait.
    This will take a few minutes. Thats it. The same things need doing for softcams but make sure you use the keys tab. Everything else is the same.
    USB, By Benny/9
    FIRST ALWAYS MAKE SURE YOU USE THE CORRECT PATCH FOR YOUR MODEL
    there are various models and only the correct patch will work or even load on your model
    • Download the correct patch for your receiver.
    • Open the zipped folder and take the patch out ready to transfer the patch onto your usb memory stick.
    • Insert your usb memory stick in the usb port under the front flap.
    • Turn the receiver on ready to load the patch then press the usb button on your remote.
    • on the next screen go to data transfer and click>OK.
    now you will see a panel with the patch on it, it will highlight, [for patching].
    press ok on the highlighted patch then it will load and when it gets to 100% and has loaded, and the receiver has re-booted [turned off and on again] and the channel opens, remove your usb memory stick. you have now loaded the patch and your channels will now open.
    you also load softcams/channel lists/official software etc:in exactly the same way by selecting
    the item you want to load.
    Note: if scrambled channel appears on channels which should open; wait a few minutes. This will enable the auto update to kick in.
    Hope this is found helpful. Sadiq999uk and Benny/9
    Last edited by .: JaCkPoT :.; 12th December, 2008 at 12:00 AM. Reason: USB added. thnx to benny/9
    Read the Rules here; they apply to EveryOne.
    __________________________________________________
    DM800s HD
    Openbox S10
    TM500
    DM500s
    90cm FortecStar dish
    Technomate 2300 motor powered by UsalS
  2. The Following 2 Users Say Thank You to .: JaCkPoT :. For This Useful Post:
    ozzy30 (1st September, 2015), partiksh (3rd June, 2017)
  3. #2
    Sep 2008
    Quote Originally Posted by Sadiq999uk View Post
    • Download the relevent patch and extract.
    • Download the relevent loader and extract.
    hi i have the technomate 6900 but all still scrambled im using s/w version 6.53p june 27th on cass menu can you advise me if ive got something wrong thank you
    Oct 2008
    watford
    Thanks for help. The AU delay has fooled me before!
    Aug 2008
    var/tuxbox/plugins
    Quote Originally Posted by titian40 View Post
    i take it your sorted now.
    DM800s HD
    Openbox S10
    TM500
    DM500s
    Nov 2008
    can i use a usb flash pen instead m8?
    Aug 2008
    var/tuxbox/plugins
    If you got usb receiver then ofcourse.
    DM800s HD
    Openbox S10
    TM500
    DM500s
    Nov 2008
    the patch wont go on the pen
    Aug 2008
    var/tuxbox/plugins
    You have to extract the file first, the box cant unzip or extract. Try that.
    DM800s HD
    Openbox S10
    TM500
    DM500s
  10. #9
    Nov 2008
    what is the difference between patching and softcam ?
    there appears to be new for both almost daily, do they need patching daily ?
  11. #10
    Aug 2008
    var/tuxbox/plugins
    A patch is firmware/software to help your receiver work which has keys already in it but when they expire they need to be updated to thats what the softcam does.
    DM800s HD
    Openbox S10
    TM500
    DM500s
  12. #11
    Nov 2008
    yes when i try to extract say something about cant do it
  13. #12
    Nov 2008
    Quote Originally Posted by dabba View Post
    and do the soft cams AU?
    how often on average do they req updaing ?
  14. #13
    Aug 2008
    var/tuxbox/plugins
    Keys au very regularly on some channels and on others after a period of time.
    DM800s HD
    Openbox S10
    TM500
    DM500s
  15. #14
    Nov 2008
    I ve just joined this website. I have no experience of satelitte receiver . How can I download technomate loader for my 6900 Combo?
    Dadadere57
  16. #15
    Nov 2008
    go to the technomate download select ur box and download patch
