Hey guys, I just replaced burnt transistor but now I have 01318 16-00 Signal outside specifications two lines of same fault on 2002 audi a4 b6 2.5 v6 tdi. Does this mean I killed the board while repairing? I can't find the answer to this nowhere on the internet. Someone asked here on page 50-ish and got no response. Also, when removing the ECU I noticed that part of the isolation on solenoid wires was gone and they might've shorted out or was this caused by the bad transistor? Also, when connecting the plug to the pump while on ignition it makes this fast clicking sound for a second or so. Is this normal?
thank you for this thread
thank you very much
Hi, trying to help a colleague with the repair of the VP44 injection pump computer, having some knowledge and equipment in the electronics, following the documentation, I replaced the transistor with a LR2905 that I fixed with the Arctic Silver thermal conductor. The computer was mounted on the pump, the car started relatively easy, stopped after 5 minutes. He did not want to start. Taking the pump calculator checked, the transistor LR2905 burnt as well as the pin 2 (common with S transistor) and the PCB, array / interrupted. Please, if anyone knows what the cause is and possibly the solution. Thank you!
Bad technology repair only soldering transistor no arctic silver give someone who fixes it because for a moment psg5 will be death
fartib (18th May, 2017)
Hi guys, my first post here!
First of all thanks to all guys who have contributed in this forum. ������
To the problem now
I am in big trouble with a transistor, I can't solder it on the pcb of the pump. Please I need some guidance on how to solder it. PLEASE HELP!!!
I will try to put some pics.
i need help with repair, i burn 2 points .
Here is the link of my picture ... https://drive.google.com/drive/folde...E1Tck4zaTgwMG8
Please help , who have experiences with repairing and problem like my .
i have fault "No communication and RPM of pump "
best regards,
davor
Chip Tuning EGR OFF DPF OFF DTC OFF Car Electronic Repair Service !
BusCan (11th July, 2018)
hello i have repaired a VP44 ECU from a Ford Transit i replaced the burned transistor and now the car does not accelarate well i have these fault codes
P1664 FIP Malfunction
P1564 FIP Reguesting Reduced Fuelling Mode
these fault codes i have also before i repaired the ECU but the car was not starting at all, if anyone can help me.
Thx.
Hi guys,
i have vp44 Herr in my table, Problem is that this little 1 x 1 mm pad where we have to solder on is gone. Is there any other spot wie can solder our wire in instead? Thanks
Are you guys using alusol or standard sn60 pb40 solder? Its really hard to solder
please anyone ???
abdulsattar (6th July, 2017)
hello to all DK experts i have this Ford Transit with no start i have repaired the VP44 ECU with changing the burned transistor and the car started ok after the repair but the car does not accellerate well on the road and the faults in VP44 ECU is 52 angle sensor/iwz system i have replaced also the sensor in the pump with new one, now i opened again the ECU and i see this stuff in the voltage regulator inside the red circle that i have point i can't understand what is that because before the repair there wasn't maybe is from temperature in engine ECU i have these fault codes
P1664 Fip Malufunction
P1564 Requesting Reduced Fuelling Mode
if anyone has an idea what is going on with this car.
Does anybody know how to get the vp44 back to Top dead centre again
im stuck with this any help will be highly appreciated
