Bosch VP30 VP44 injection pump repair solution - Page 81
Page 81 of 96 FirstFirst ... 3171767778798081828384858691 ... LastLast
Results 1,201 to 1,215 of 1429
  1. #1201
    belgrade,serbia
    you can do it with comparator ,on place where is pump blockade ,put comparator and rotate pump till 0.8mm
  2. The Following User Says Thank You to vladanr For This Useful Post:
    abdulsattar (28th July, 2017)
  3. #1202
    Top Poster abdulsattar's Avatar
    Nov 2016
    Thanks for your reply, Please explain more. Which tool is required and where do we have to put it? Thanks friend
  4. #1203
    dunkler's Avatar
    May 2009
    Hatzfeld
    Hi DK
    I have a VP44 pump from a E46 320d, replaced burned transitor with IRLR2905, car started fine but died second day. My first guess is overheated transistor, although I used artic silver thermal compound. Is there a way to get a better cooling? Thermal adhesive is better? Thanks
    LE: Solved!
  5. #1204
    Vegaz
    Quote Originally Posted by abdulsattar View Post
    Hi guys,
    i have vp44 Herr in my table, Problem is that this little 1 x 1 mm pad where we have to solder on is gone. Is there any other spot wie can solder our wire in instead? Thanks
    Hi mate
    good luck
  6. The Following User Says Thank You to vey81 For This Useful Post:
    Liliana48 (30th January, 2019)
  7. #1205
    Mar 2013
    Quote Originally Posted by stevan View Post
    I have one here but as i have mesured MOsfet is ok,not have short between source and derain or some resistance but i have strange resistance 91R between two pin on other side.
    Fault in this case is voltage regulator ,replaced with 78S05 (1.5 amps) ,maybe an ordinary 7805 will work too ,current is about 0.17 amps
  8. #1206
    Mar 2013
    Have another with timing valve being actuated all the time even no rpm from engine , any ideea ?
  9. #1207
    Argentina CABA
    Very Goods!!!
  10. #1208
    Oct 2016
    Should i remove pump or just psg I do not think it's necessary to take out the whole pump?
    BMW 320D
  11. #1209
    Oct 2016
    Quote Originally Posted by dunkler View Post
    Hi DK
    LE: Solved!
    How did you solve problem and what was the problem?
  12. #1210
    Apr 2011
    Quote Originally Posted by vey81 View Post
    Hi guys,
    please help me with this.
    Audi 2.5tdi, MY 2003.
    Control Module Part Number: 8E0 907 401 M
    3 Faults Found
    01318 - Control Module for Injection Pump (J399)
    03-00 - No Signal
    49-00 - No Communications
    17978 - Engine Start Blocked by Immobilizer
    P1570 - 35-00 -
    in block 18 read as follows:
    Supply voltage injection pump - 0.00V
    Supply voltage from ECM - 11.83V.
    Fuses O.K., supply and GND on conector is O.K, CAN is 120 ohm, original MOSFET is ok.
    Pump doesn't communicate via k-line [focom, op-com, vr diag], and even after the power is there no sound as the other PSG5.
    Is there any chance how to wake up the pump unit?
    Thanks for your help
    I want to write private message to you, but error message says that you had exceeded message quota
    Anyway, I have exactly the same problem as you had, can you tell me how you solved it?
  13. #1211
    DK Veteran stevan's Avatar
    Bosnia
    Anybody know where this lead from RPM goes?
  14. #1212
    Hungary
    I measured every lead, I did not find a direct pin.
  15. #1213
    Bosnia
    Quote Originally Posted by Pepita View Post
    I found only 700R to GND
    Poslano sa mog ZTE Blade V6 koristeći Tapatalk
  16. #1214
    May 2013
    my vp44 has the error p1335. Hall sensor is new, but the engine does not start. the driver is already on the table but I have no ideas
  17. #1215
    Nov 2017
    PSG5.jpgLift the capacitor up. Marked in yellow. And solder again.
