Page 83 of 96 FirstFirst ... 3373787980818283848586878893 ... LastLast
Results 1,231 to 1,245 of 1430
  1. #1231
    Apr 2012
    BG V.T.
  2. #1232
    May 2018
    Thanks stevebbb, much appreciated!
    May I ask how you worked this out? Do you have a schematic diagram, or have you made your own measurements?
  3. #1233
    May 2018
    I measure these points as connected in blue:
    I believe these are the source (-ve) connection.
    I need a connection to the small pad above in red for the drain. Am I looking at this somehow wrong?
  4. #1234
    Apr 2012
    BG V.T.
    sorry for the mistake...
  5. The Following User Says Thank You to stevebbb For This Useful Post:
    dynasat (31st May, 2018)
  6. #1235
    May 2018
    Thanks stevebbb for the correction.
    Despite being an electronics engineer, I'm struggling to solder to these virtually microscopic components and pads. Do you happen to know whether there's anything else connected to this node between the drain and capacitor?
    I think I made a mistake trying to do this leaving the unit in the car. I'm contemplating instead soldering a 1nF capacitor between the source and drain, but wondering if there's anything else connected here, or whether this point may be involved with the PSG pin 5 MAB signal feedback to the ECU.
    I'm getting close to the point of throwing in the towel and buying a new pump.
  7. #1236
    Apr 2012
    BG V.T.
    I think it's just a capacitor to ground, nothing else connected.
  8. #1237
    Jul 2018
    Northern Ireland
    Hi all, I have a dead short on pins 6 & 7 (Gnd and +12v) on my Transit Connect's VP30. Could the fault still lie with the transistor? I have 2 IRLR2905 sitting waiting here. No visual indications anything else has gone...
  9. #1238
    Mar 2013
    If this photo is the real unit and there is a short between 6 and 7 then transistor is out of the question ,maybe 5 volts regulator which is on the next corner ( reverse clock counting ) .Or you can use a regulated voltage supply and inject 1,2 or more amps and watch for heating components ,maybe a cap is shorted ...
  10. #1239
    Jul 2018
    Northern Ireland
    Quote Originally Posted by TR0UBLESH00TER View Post
    Thanks Tr0ublesh00ter, I followed the 'repair vp 44 pump' guide and found the 5v regulator also to be faulty (dead short +12v to ground). That's out of the circuit now, but there's still only <1k resistance between +12v and ground, and I seem to see a dead short between +5v and ground. I suspect you're right, and a downstream cap has failed. At this rate, it's maybe not worth fixing, but at least I'm learning....
    The photo is my actual unit, yes.
    Update: I've just removed every component with a short off the board and there's still a dead short on the 5V line. I think it's dead :-(
  11. #1240
    Mar 2013
    Anyone use scope and current clamp to check valves conditions ?
  12. The Following User Says Thank You to TR0UBLESH00TER For This Useful Post:
    mexanico1971 (22nd May, 2022)
  13. #1241
    May 2018
    Hello!
    I need the Mosfet small PCB alternaive point, the link is dead.
    Thanks!
  14. #1242
    Apr 2017
    Hello, I'm sorry but I have a different kind of question
    where is the fuel temperature sensor located in VP44?
  15. #1243
    Apr 2012
    BG V.T.
  16. The Following 3 Users Say Thank You to stevebbb For This Useful Post:
    faza952 (24th July, 2018), koruptx2 (5th October, 2018), SERBAN 70 (25th June, 2023)
  17. #1244
    May 2018
    Thanks !
  18. #1245
    May 2018
    I changed MOSFET irlr2905 in astra G y20dth and i have P1560 (pump system voltage) What is the problem?
