Page 84 of 96 FirstFirst ... 3474798081828384858687888994 ... LastLast
Results 1,246 to 1,260 of 1429
  1. #1246
    Dec 2016
    hun
    Do you know which one is the best transistor?????
  2. #1247
    Oct 2017
    very good information, it still does not work.
  3. #1248
    Aug 2018
    Has anyone honestly been able to
    perform a lasting VP44 transistor
    repair? Looks like some tricky soldering, lots of uncertainty as to what type transistor to use, questions as to what type transistor Bosch used originally and wether calibration is required after? Best way to secure for required heat sink? I’m in Canada,
    new to the forum with a Dodge truck and melted transistor wire to
    fuel valve drive transistor. Read tons, watched all the videos but seems nobody getting lasting repair and then discusssion ends??? I understand these pumps are much more common in Europe. Sure be great to hear a good success story from someone not trying to sell something.
    Cheers, Gary
  4. #1249
    Aug 2018
    Transistor in the way. Guess I’ll do my best as an Electronic Technologist with lots of soldering experience. I hope to post some good news.
  5. #1250
    Aug 2018
    Sorry, meant to say transistor “on”
    way.
  6. #1251
    Sep 2018
    Hola a todos mi focus tddi 1999 funciona pero no acelera bien hasta estar en temperatura. Quiero decir lo arrancó y arranca bien pero demora unos cuantos minutos en responder al pedal. El error a tiro spc fue p1564. Gracias a todos. Un saludo
  7. #1252
    miha99's Avatar
    EU
    Ditworks2 i use dpack irlr2905 mosfet (i newer buy in China), but trick is in soldering!
  8. #1253
    Oct 2017
    Hello everyone.
    Change the mosfet to two psg5 of Focus and one of astra, I am testing with a pump in the test bench, with the three modules I only have a wide signal in the valve a couple of times. The other pulses are very narrow and do not actuate the valve.
    Will it be for not trying on the vehicle? I take a few captures, one with a wide pulse when the valve is activated and the other with the narrow pulses that do not activate it. Greetings and thanks.
  9. #1254
    belgrade,serbia
    best fet for pump is irlr3110.if you check signal of valve on bench for ford you must unlock electronic ,code is in electronic
  10. #1255
    Oct 2017
    Thanks for your help.
    He has the 3110
    I will try to delete the code. Although I do not think it explains why sometimes it shoots and sometimes it does not, as the images show. Then I comment the results.
  11. #1256
    Oct 2017
    I put in the car, immediately p1554 and p1664. I can not erase.
  12. #1257
    Mar 2013
    Check +12v on the pump module connector
  13. #1258
    Oct 2017
    Checked 12v, ground and can.
    Module psg5 with kts570 does not present errors.
  14. #1259
    belgrade,serbia
    check preinjection fet,and capacitor for pump rpm
  15. #1260
    belgrade,serbia
    and check 5v stabilisator
  16. The Following 2 Users Say Thank You to vladanr For This Useful Post:
    Bigfordushka (19th November, 2018), SERBAN 70 (25th June, 2023)
