Is this? I have 0 resistance.
RPM and 5v is ok.
I leave a video, listen to the activation of the valve, only when I go up or down, at a few rpm.
RPM and 5v is ok.
definitely you shouldn't have 0 ohms there. I don't have a module here to test but maybe someone can give more clues to it
I'm waiting for confirmation from a partner.
Is this a retention mosfet? Through the R of 1.8 ohms?
that is preinjection fet and hi is problem you have short circuit between gate and source.change it ,you can put 2905 or 3110
Bigfordushka (19th November, 2018)
Change the fet and now I have code U0105.
5v is correct.
I did not have that error before.
Anyone has had the P1629 and P1651?
I repaired a Saab PSG5 and it ran mostly ok but with a few problems. Now wont start without "help" and shows those 2 codes on the scanner...
P1629 Fuel Quantity Solenoid Valve Malfunction
P1651 Pump Control Unit malfunction
(this on tech2)
May it be the actual solenoid or the spring is broken inside?
Hy everybody...i have problem with a vp44 pump (audi A6, 2001), after changing mosfet irlr 2905 and istalled in pump , now the car is smoking (white smoke) , any ideeas? ..thx in advance !!!
Hi Friends.Can someone povide me about unit nr replace? I heave broken ecu from vp44 nr:0 281 010 479 I would like to know what nr I can replace?BR
Please dear members push the button if my work was helpfull!
And reputation button(star)
salut c est plus du dépannage que de la reparation vous en pensé quoi
Can someone can confirm if this transistor work good-IRFP064N.I put this on bmw e46 320d car start but not have power.Can be from this transistor?
Hello i try this transistor IRFP064N but car not have power with it.Starts fine work fine but not have any power.Dont use it!!!
Hello all
Car is a Ford Focus 2001 1.8 TDDI 90 cp , no start with the following errors P1664 , P1564 .Popped the pump lid and found one aluminium wire trace blown, tried to jump the trace but no start so my question is can someone please point me to which mosfet is right for this engine irfz44n , irlr3110zpbf or IRLR2905 .Pump has 12v at pin 7 with key on and ~5 ohms between pin 6 and ground .Thank you
Hi!
I have in garage 2.5 tdi and vp44 transistor is blown away so i put new transistor irlr 3110 and car start but error 01268 and 3k rpm.
Have done some research for transistors that we have use and years are passing but we don't know are they really good substitution for repairing or not?
Is there some transistors with better characteristics that we can use?
