Page 12 of 96 FirstFirst ... 278910111213141516172262 ... LastLast
Results 166 to 180 of 1430
  1. #166
    Member ssivov's Avatar
    Bulgaria
    password please!
    thanks!
  2. #167
    Well, you can be sure that the solenoid coil is not open-circuit, but not that it doesn't have shorted turns - unless you have a very accurate meter, with a 'divide by' function. If you can remove the solenoid , you could bench test it, by applying a test voltage from a suitable source and checking if it switches - or by measuring the current flow through it.
  3. #168
    Estland
    Does somebody know what component is that,shown on picture.
    In my unit all small wires are open from there.
  4. #169
    It is difficult to see clearly, but it looks like a surface-mounted iintegrated circuit.
  5. #170
    Default Hi
    I am from Estonia and I have Ford Focus 1,8td. 1999year
    I have the same problem, the pump is dead.
  6. #171
    Estland
    And?
    If you want I can replace the solenoid control transistor.
    Other things in Estonia,i think you know :
    Diislimeister O? or Karla Auto
    New ecm 6700.- eek,Programming and adjustment 3800.-
    I have 320d and also trying to find cheapest way to fix it.
  7. #172
    Senior Member drivergabriel's Avatar
    BUCURESTI
    in that picture it-s an eeprom something like 24c04 or 95po8
  8. #173
    Estland
    Are you sure,it looks like all wires are connected to same plate.
    4 wires from right goes to -12V
    ........ it?s realy possible 24c04
    Did you ever change it,where to get a dump?
  9. #174
    anyone knows if there any software able to test VP44 on generic diesel pump test benches?
  10. #175
    Quote Originally Posted by AUTRONIKA View Post
    i have this tool
  11. #176
    BUCURESTI
    onli ,,carprog'' can really do that!
    and about that eeprom.... i dont think is posible to change it... everything is posible, i know that, but is too much work for nothing!
  12. #177
    Hi all !! There is a way to test the functionality of the computer pump when the pump is out of the car . For exaple to connect FPCM to computer and software to be able to simulate and receive data from the pump ?
  13. #178
    Estland
    Is it possible to take PSG5 electronic module from another car pump ?
    Does somebody have a new or used ECM for sale?
  14. The Following User Says Thank You to nizu For This Useful Post:
    bn99nas (10th April, 2017)
  15. #179
    BUCURESTI
    yes! read:
    BMW: you can swap the pump and after that you can syncronize-it with inpa!
    OPEL: just ,,plug and play'' (from opel to opel)
    AUDI: just ,,plug and play'' (from audi to audi)
    FORD: i am not sure
    SAAB: just ,,plug and play''
  16. #180
    Estonia
    Quote Originally Posted by nizu View Post
    And?
    Where you from in Estonia?
    And how much is your tax for replacing this transistor?
