It looks like capacitor, you can remove it and measure with digital multimeter
I have already measured ~3nF.
anyone else could confirm the value?
best regards
For ALL:
[ame=http://www.youtube.com/watch?v=UiJ-13vldWg]YouTube - VP44 NPARAWA[/ame]
question:
From where can I find the schematic for this pump?
many thanks in advance for your help.
best regards!
do u mean internal wiring or what?
yes, internal electrical wiring (schematic)
best regards!
I have here one pump from Opel/Vauxhall Vectra B,2.0 DTI.
I allready changed broken transistor but car don't want to start.
Erorrs are P1630 and P1631.
What next?
Any advice,experience...?
Thanks in advance
Best regards
Pump has a faulty control unit. Best way is to have it serviced by a Bosch Diesel Center, but it may be expensive.
Can a help to replace transistor for error code p1220 ?
P1220 a timing deviation fault on the VP44 pump. The only thing you can do is to replace fuel filter, and/or check if air is being pulled into the system. If this doesn't fix the P1220 fault, pump has to be rebuilt.
Great solution. Thanks everyone for share some good information that helps us to save a lot of money.
Greetings from Portugal!
Many thanks Gabriel, we have replace the MOS FET on the pump and it works !
but the car start and stop after 10 minutes; we think it's another problem now, we are investigating.
So, you're the best Mr. Gabriel
Regards,
Youssef from Morocco
thanks for the contribution
