how can I effectively clean the valve?
Would anyone know the value of this capacitors?
Thanks...
is a capacitor, 3NF
Thanks...
It's fixed now...
can sambady help me: Audi 2.5 VP44 diesel pump which MOSFET need?
it just goes wrong?
A3PA (30th January, 2017)
Thanks!!!
And this IRLR 2905 PBF ***8203;not good?
Thanks!!! I used the 2905 for Opel and BMW, and it's good working.
Hi All!
what do you think the irf1405 mosfet. this good or not in the audi a6 vp44 pump?
I changed the mosfet the in the pump but not working.I used irfz44n .Im started the car but not working. After I chek the mosfet and I saw gate wire is broken .
I think I use this fet IRF1405
http://www.redrok.com/MOSFET_IRF1405...4.0_TO-220.pdf
This good or not.
thx.
a friend has a 115hp mondeo that stood running, the problem is that the pump disconnected without removing the battery, so we will have to reset after changing the transistor. currently read failures P1665 and P0216.
I have not seen damaged the pins can be damaged on the original fet burned without sideburns? Also think it could be the position sensor
I read that there are people who repair the ford with IRLR2905PBF (I have it) but another recommended in IRL3803, I test with the 2903 or wait and buy the 3803?
Hi!
I tested the Opel vectra B 2.0 dti and Astra G 2.0 dti and BMW 320D with 2905 and this good working!
Hi Guys!
Can samebody help me?
I have a wrong Vectra B 2.0 dti diesel pump ecu, i check the 1. transistor but it good!
The 2. transistor wrong. Which transistor need for me? Maybe IRLR2905???
Thanks the help!!!!!
I changed the IRLR2905PBF in the Mondeo, and now it works fine.
