Page 85 of 96 FirstFirst ... 3575808182838485868788899095 ... LastLast
Results 1,261 to 1,275 of 1429
  1. #1261
    Oct 2017
    Is this? I have 0 resistance.
    RPM and 5v is ok.
    I leave a video, listen to the activation of the valve, only when I go up or down, at a few rpm.
  2. #1262
    Jun 2009
    Porto
    definitely you shouldn't have 0 ohms there. I don't have a module here to test but maybe someone can give more clues to it
  3. #1263
    Oct 2017
    I'm waiting for confirmation from a partner.
    Is this a retention mosfet? Through the R of 1.8 ohms?
  4. #1264
    Apr 2010
    belgrade,serbia
    that is preinjection fet and hi is problem you have short circuit between gate and source.change it ,you can put 2905 or 3110
  5. The Following User Says Thank You to vladanr For This Useful Post:
    Bigfordushka (19th November, 2018)
  6. #1265
    Oct 2017
    Change the fet and now I have code U0105.
    5v is correct.
    I did not have that error before.
  7. #1266
    Jun 2009
    Porto
    Anyone has had the P1629 and P1651?
    I repaired a Saab PSG5 and it ran mostly ok but with a few problems. Now wont start without "help" and shows those 2 codes on the scanner...
    P1629 Fuel Quantity Solenoid Valve Malfunction
    P1651 Pump Control Unit malfunction
    (this on tech2)
  8. #1267
    Jun 2009
    Porto
    May it be the actual solenoid or the spring is broken inside?
  9. #1268
    Jun 2009
    Porto
  10. #1269
    tazz75's Avatar
    Nov 2018
    Hy everybody...i have problem with a vp44 pump (audi A6, 2001), after changing mosfet irlr 2905 and istalled in pump , now the car is smoking (white smoke) , any ideeas? ..thx in advance !!!
  11. #1270
    drewdom's Avatar
    Aug 2010
    58?59'13.1"N 6?11'19.4"E
    Hi Friends.Can someone povide me about unit nr replace? I heave broken ecu from vp44 nr:0 281 010 479 I would like to know what nr I can replace?BR
    Please dear members push the button if my work was helpfull!
    And reputation button(star)
  12. #1271
    Newbie nasisamy's Avatar
    Dec 2018
    salut c est plus du dépannage que de la reparation vous en pensé quoi
  13. #1272
    Mar 2014
    Can someone can confirm if this transistor work good-IRFP064N.I put this on bmw e46 320d car start but not have power.Can be from this transistor?
  14. #1273
    Mar 2014
    Hello i try this transistor IRFP064N but car not have power with it.Starts fine work fine but not have any power.Dont use it!!!
  15. #1274
    Jan 2017
    Hello all
    Car is a Ford Focus 2001 1.8 TDDI 90 cp , no start with the following errors P1664 , P1564 .Popped the pump lid and found one aluminium wire trace blown, tried to jump the trace but no start so my question is can someone please point me to which mosfet is right for this engine irfz44n , irlr3110zpbf or IRLR2905 .Pump has 12v at pin 7 with key on and ~5 ohms between pin 6 and ground .Thank you
  16. #1275
    Mar 2013
    Random
    Hi!
    I have in garage 2.5 tdi and vp44 transistor is blown away so i put new transistor irlr 3110 and car start but error 01268 and 3k rpm.
    Have done some research for transistors that we have use and years are passing but we don't know are they really good substitution for repairing or not?
    Is there some transistors with better characteristics that we can use?
