you can do it with comparator ,on place where is pump blockade ,put comparator and rotate pump till 0.8mm
abdulsattar (28th July, 2017)
Thanks for your reply, Please explain more. Which tool is required and where do we have to put it? Thanks friend
Hi DK
I have a VP44 pump from a E46 320d, replaced burned transitor with IRLR2905, car started fine but died second day. My first guess is overheated transistor, although I used artic silver thermal compound. Is there a way to get a better cooling? Thermal adhesive is better? Thanks
LE: Solved!
Liliana48 (30th January, 2019)
Have another with timing valve being actuated all the time even no rpm from engine , any ideea ?
Very Goods!!!
Should i remove pump or just psg I do not think it's necessary to take out the whole pump?
BMW 320D
Anybody know where this lead from RPM goes?
I measured every lead, I did not find a direct pin.
my vp44 has the error p1335. Hall sensor is new, but the engine does not start. the driver is already on the table but I have no ideas
PSG5.jpgLift the capacitor up. Marked in yellow. And solder again.
