Page 3 of 7 FirstFirst 1234567 LastLast
Results 31 to 45 of 94
  1. #31
    DK Veteran rsibiza's Avatar
    Exclamation
    Quote Originally Posted by aminebot View Post
    had someone tested this tool on EDC16 ?
    I tested on a LEON 2009 2.0 TDI but it does not work ;
    any idea ?
    I tryed on Audi A3 2006 2.0 TDI EDC16,can detect ecu,start reading and freezes ....
    After 50 minutes,i stopped,tryed again,and same result...
    So i dont think it will work on edc16...
  2. #32
    Member Flash_chip's Avatar
    Quote Originally Posted by rsibiza View Post
    what do you like interface? box blue or black interface?
    what version software?
    if you can not do with "VAG DASH CAN" with what can be done to clone EDC16? I'm afraid we have no choice and must go to the original!
    I looked at Abritus72, there is 1266? for:
    -Interface Avdi 720?
    -AN002 - Odometer by CAN 246?
    -AN012-A-- EDC16x - Odometer by OBDII 300?
    it is expensive.
  3. #33
    Quote Originally Posted by Flash_chip View Post
    it is expensive.
    I(f you read some posts about the original tools,you would also see,that original tools have problems doing the edc16 odo.....maybee best choice would be BDM100...
  4. #34
    If you read some posts about the original tools,you would also see,that original tools have problems doing the edc16 odo.....maybe best choice would be BDM100...
    Why not, I want to buy a BDM100, but the problem is that often the BDM100 clone are mounted upside down with a risk of burn out the ECU!
    plus the ECU must be removed! there are customers who prefer to spend as OBD, but why not if it has no choice.
    BDM100 can do with the ECU and not the dashboard, right?
    Thank you
  5. #35
    Exclamation
    Thank you
    Yes,BDM100 can just do EDC16/16+ ecu's and MED9xx ecu's
    I use original EVC BDM,so nothing is mounted upside down...but be aware from cloned BDM...improper mounting is not the only problem.
    The model with power supply,may in some cases provide more than the needet voltage to ECU,and ecu will also be death after this for reading or writing to it,but still working in car
  6. #36
    then after you, I must find a BDM100 powered by USB, it will be less risky?
    if you know the connection to ECU for change KM?
    BDM in the original CTS, cost?
    According to the panel to go through R250?
    did you connect?
  7. #37
    Red face
    did you connect?
    BDM is for reading flash eprom mcu of ecu's...R200/R250 is for reading dash,i dont have it...
  8. #38
    dyc's Avatar
    buy magic dash can is worth his money ,Im using since 1 year and is the best ,very offten made dash or edc 15,16 which vag dash can not , and is possible to make more dashes from older cars too.
  9. #39
    z786's Avatar
    10 Steps Ahead of You
    are you talkin about the vagdashcan or the software some1 uploaded on this thread?
    "I always tell the truth. Even when I lie"
    "We Taking Over, One City At A Time"
  10. #40
    Quote Originally Posted by z786 View Post
    The uploadet soft here from post nr?,but the on from here,used with KKL interface...identifies ecu correct,but freezes after while reading....it may also possible it take 2 hours?,but i wont believe this...not for so little eprom
    Best regards.
  11. #41
    you do the ECU with your BDM100 and how you do to the dashboard?
    did you connect the BDM on ECU?
  12. #42
    Quote Originally Posted by dyc View Post
    you've tested on any car with EDC16?
    you bought what site?
  13. #43
    tehnosoftex's Avatar
    Romania
    Bdm 100 from evc is for no use if you didn't have also original winols, I have also vagdashcan clone vers 5.05 and it works on almost all edc16 which I test. For passat or touran 2.0 ppd did not work because the ecu is siemens, but also vcds cannot retreive it. Today I try to read a audi a6 2.7 tdi edc16 from 2008 but vagdashcan give me a scifi value. I do not proceed whit the writing, but I save the dump. I analyse later and I see the original mileage. Also vcds cannot read the mileage from that ecu.
  14. #44
    Quote Originally Posted by tehnosoftex View Post
    Your VAGDASHCAN made the EDC16 Audi? example of vehicles tested and their year?
    you can change the KM (in ECU & Dash)?
    what site you bought your VAGDASHCAN? "PM" if you do not want to advertise.
    what is it value "Scifi?
    Normally, if you have a recent version of VCDS (I think from 908.0), you have the button EDC15/EDC16 mileage.
    Thank you for your sharing information.
  15. #45
    dyc's Avatar
    I have tested on many edc16 magic dash of course original (there is no cloned interface) and vag dash can 5.05 cloned
