Page 10 of 11 FirstFirst ... 567891011 LastLast
Results 136 to 150 of 152
  1. #136
    Oct 2015
    Please, help me whith file for Beeprog 2.67 clone ,what was check.Thanks.
  2. #137
    Oct 2015
    Quote Originally Posted by gopelhu View Post
    Hi all,
    Here is again the Beeprog PIC content with CFG... ENJOY !!!
    Regards, G
    This file for Beeprog+
  3. #138
    ykizak's Avatar
    Nov 2011
    South Africa
    i have a pickit 3.5 clone and i cannot write 40kb files. Size must be 46kb for some reason. Can anyone tell me if there is a way to write 40kb files with mplab x ipe please?
  4. #139
    Apr 2019
    merci de me aider je cherche les fichier pour beeprog china version 2.67
  5. #140
    May 2017
    Espaņa
    English please
  6. #141
    Dec 2014
    algerie
    thanks thanks thanks
  7. #142
    Dec 2011
    Gentlemen, has anyone managed to update Beeprog rice to the latest version? I use 2.92
  8. #143
    Jun 2013
    Kikinda Serbia
    Is it possible that the Beeprog Elnec team stopped my developer work? So far it has worked fine, I bought it as a legal programmer not a Chinese clone. I sent you a report file. If I have to repaire it, write the bin file in PIC and 3xEEproom 24C02? I also send you the read eprom. Does my serial number remain? Help me get my programmer back .... Thanks
    When the programmer turns on the voltage. The LEDs are lit at full intensity one at a time by POWER-BUSY-GOOD-ERROR and then remain illuminated by lower-intensity POWER LEDs
  9. #144
    Jun 2013
    Kikinda Serbia
    I'm not sure if the problem is hardware even though I looked through everything without the schema I have good voltages 14V 12v 5v 3.3v 2.7v ..... Or the problem is Software
  10. #145
    Jun 2013
    Kikinda Serbia
    When a man does stupid things. Problem solved. The problem was the version of the program. I knew that my BeeProg was not supported by new versions. But I don't even know how I installed it on the computer I was constantly working on. I installed the other two and I don't remember when I'm on a work computer. Basically the largest version of the software is 3.32 which supports BeeProg. BeeProg2 and BeeProg + can also have New versions. Stupid on my part but when it stops working the most important tool in the workshop ...... PANIC
    There is also one good thing about all this, I will share the picture with the required voltages on the board. When someone has a problem with BeeProg hardware ..... Hope no one will have such a problem
  11. #146
    Top Poster zapdus's Avatar
    Jan 2017
    Hi all,
    Regards, G
    I can confirm
    It is working
    Program with pickit3
  12. #147
    Dec 2014
    algerie
    Thanks Elvis
  13. #148
    Apr 2020
    does anybody know if software version 3.0 work with all beeprog clone or only with from there?
  14. #149
    Apr 2020
    RadovanPetkovic.You were able to pick up the Beeprog programmer?
  15. #150
    Jun 2013
    Kikinda Serbia
    BeeProg works great. Be sure to clean the Eprom and processor pins well because BeeProg "sees" the lowest resistance outside of the one listed in the catalog for a given chip. It often reports contact errors for some pins. They will read it only if everything is according to the regulations and that is why they give it that less than 1% is a possible mistake
