Results 1 to 8 of 8
    Aug 2015
    Default Nissan stagea 93c46 eeprom content needed
    Hi!,
    Power loss caused eeprom content damage, and now mileage is not displayed, and speed reading is wrong....
    can someone share eeprom content.
    Car is from 96, and speed should be measured in miles/hr
    Thanks in advance!
    Jul 2015
    I’ve got some manual c56 dumps but Im guessing this is Series 1 auto if c46.
    Best bet would be to try and find a cluster from a breaker car and copy memory. I think these were kms only too?
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    Pictures. ......
    Aug 2015
    basically it is km`s, but letter 'k' is covered by sticker and i suppose that number of pulses per distance was changed in eeprom ,
    mileage is not relevant , i only need some donor eeprom to make it work correctly
    here are some pics,
    Jul 2015
    I would think it’ll have a converter wired into the harness that converts the speed signal from kms > miles. Can’t help on dump though - you’ll need a cluster from Japan I reckon.
  6. The Following User Says Thank You to Mike1001 For This Useful Post:
    rohanmuneeb (10th October, 2020)
  7. #6
    Sep 2013
    Search for other Nissan model cluster file which has the same cluster with a 93c46 inside . Then put new file in your cluster and test.
  8. #7
    Jul 2020
    Quote Originally Posted by Mike1001 View Post
    Hi Mike, would you still have the manual c56 dumps??
    Thanks in advance
  9. #8
    May 2018
    Sorry for digging old thread.
    I recently repaired same cluster (S34 Stagea S1 Auto).
    I couldn't find BIN file anywhere, and wasn't sure if mine was OK. These sometimes corrupt EEPROM the same as other late 90's nissans (navara, maxima, pulsar etc.)
    Turned out mine was fine and not corrupt. Was just dry solder joints.
    I've attached bin file for anyone who needs in the future.
  10. The Following User Says Thank You to pman92 For This Useful Post:
    jomberykaso (29th March, 2024)
