well i had the 600 working on cli image and wanted to try a different one ,dreamup would not flash. [useing laptop / vista and comport converter ] so i thaught i,d do it as you suggested with telenet. ie
mount -o remount,rw /boot
rm -f /boot/*
reboot
used putty program to do this. i had ip set on the box and i could telenet to the box before this. after putting in the command mount -o remount,rw /boot
rm -f /boot/*
reboot the box went off and came on with red light flashinrg and the odd green flashing light every now and again. now i.m stuck,any idea,s m8? thanks for the reply.also tried restarting the box with power button held down , still no joy.???????
__________________
is it a bird?......is it a plane?.....NO ITS MY CHEAP CLONE FROM CHINA GOING OUT THE ~~~~ING WINDOW.
I am doing a friend a favour by trying to get his DBox up and running, and wondering do the telnet commands that are detailed on this thread work on a dbox.
I have been using this method for my 500c and have never had a problem, so I was hoping I could flash a image using this telnet method for the DBox.
Also I know it is doubtful, but is it possible to flash DK1 image on a DBox or is this image specific to dreambox
is it easier to use telnet dcc or dreaup?
just wondering if you backup the image off one dream box is it possible to copy it over to another box so there running on the same flash software
followed your instructions to the letter and my box is useless now,i've only a green light on the front,nothing else but a black screen,no menu's or welcome screen,channels or anything,any ideas?????????how can i rescue this now?????????????
is there a similar way to use telnet to make a .nfi backup image for a 600....
Having problems with Dreambox tools v3
When I run universal dreamup I get an error "there is something alive with IP 192.168.xxx.xxx in your network that is not a dreambox. Dreamup may not work properly"
Any ideas?
hope this above will work for me.
thanks !!!!!guys!!very helpful if you dont have dreamup!!!!
Hi, Will this command work for image backup from Dreamup?
oh god...
i renamed the image wrong when i ftped it - i typed in the command and it got as far as erasing but stopped when it couldn't find a matching image file
i then repeated the command and get the error message:
"cp: unable to open '/dev.mt/3': no such file or directory"
what should i do?
edit:
nevermind i restarted my telnet client and redid the commands - which seems to have done the job
