Page 5 of 9 FirstFirst 123456789 LastLast
Results 61 to 75 of 123
  1. #61
    Default dm500+
    hello wheen i paste cd /tmp && eraseall /dev/mtd/3 && cp backup.img /dev/mtd/3 && reboot , i get -sh: eraseall: not found
    can u help me please
  2. #62
    can anyone tell me where to get a flash image for my db 500c plz
  3. #63
    May 2008
    hi
    this tut has helped me no ends
    this is my take with pictures
    hope this may help
  4. #64
    Apr 2008
    Quote Originally Posted by Devilfish View Post
    Telnet Commands
    To flash an image using Telnet
    This method will only work with a .img image file.
    • Rename the image file to backup.img
    • FTP the image file to the /tmp folder on the dreambox
    • Telnet to your box and paste the following command:
    To telnet, click START > RUN and type Telnet ip.address.of.dreambox
    A command window will appear, enter username root and password dreambox.
    Oh no. I decided to flash my Dbox again but...
    I did all this without placing the backup.img file into the tmp folder of the DBox
    Now my Dreambox is completely dead because i think that command deletes everything. The light is on but theres nothing on screen even the remote does not work
    How will I flash my Dbox now? Knowing that I have no idea what the IP is.
    HELPPPP!
  5. #65
    May 2008
    hi
    beretto
    have a look at Guide: Flashing a Dreambox with Dreamup sticky
  6. #66
    Apr 2008
    Thanks bob. It worked a charm.
  7. #67
    DK Veteran harky's Avatar
    telnet seen to be abit hard for me to flash my dm500c.. Zzz
    i had d/l PuTTY as i m using vista but when i enable the prog and feature
    Run - Telnet ip.address.of.dreambox
    it popup but than later the window gone i assume it cannot connect how ?
    btw it a new setbox..
  8. #68
    update
    manage to get it flash thanks.
  9. #69
    Thanks for the info
  10. #70
    thanks for guide much appreciated
  11. #71
    uk
    Default dm 500
    thanks for info
  12. #72
    hello anyone has a new DSM image backup file for the dm 500s. channel gone. new at this box already set up for this. help please
  13. #73
    Newbie sbu7360's Avatar
    Singapore
    dear all, i'm kind of confused..
    do i flash the image 1st or do i do a backup 1st?
    i'm stuck at the point where i'm asked to ftp the backup.img to the box... i really dun noe how to work tis step.
  14. #74
    Singapore
    dear all, may i noe if i'm successful wif the flash, wat will i see?
  15. #75
    hello i m new here.. have problems with my set up box. need help
