Page 8 of 9 FirstFirst ... 3456789 LastLast
Results 106 to 120 of 123
  1. #106
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    This method won't work with a DM800, I've been out the came for a ages now so can't help you further, sorry.
  2. #107
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    u have to flash from the boxes webpage m8 , power up box with your finger on the power button . u will see message stop and remove finger and u will see an ip address , but that in your browser and u have an option to flash an image , search for it and flash
  3. #108
    Bulld0g's Avatar
    Apr 2008
    Liverpool
    As above, flashing this way takes about two minutes. When you add your bouquets etc and set the box up the way you want it, go to MENU...SETUP....SOFTWARE MANAGEMENT....BACKUP SYSTEM SETTINGS.
    Next time you flash another image you can add these settings, as above but using RESTORE SYSTEM SETTINGS. no need to make a back up of your image when you can save your settings and just restore them to a new image. Takes about 2-3 minutes in total.
  4. #109
    Nov 2010
    Hi, I'm using DM500(Sliver), currently only can watch normal channel.
    I wanted to refresh but keep having invalid login.
    I tried the username and password given (root / dreambox) but still fail.
    Is there any other username and password can be use?
  5. #110
    Oct 2011
    Default how do i flash my 518s without killing it?
    i have bought a dreambox but have no idea how to set it up without frying it. can anybody help?
  6. #111
    Jul 2011
    [ame=http://www.youtube.com/watch?v=BovvFtD6Cis&feature=related]Flash Dreambox Without Serial Cable - Using FTP & Telnet Tutorial - DM500 - YouTube[/ame]
  7. #112
    cork ireland
    thanks for all the info ....im off to Maplins on tuesday thanks again
  8. #113
    Feb 2009
    Quote Originally Posted by mizen1 View Post
    Lol. If you're looking at a network cable, do not go to Maplins. You're going to get ripped off. If it's quality you want, then go on eBay and type in cat5e 350MHz and find some cable from there, but otherwise I'd not bother with Maplins at all
  9. #114
    cork ireland
    Default maplins and network cables
    [QUOTE=waqasahmed;1581277]Lol. If you're looking at a network cable, do not go to Maplins. You're going to get ripped off. If it's quality you want, then go on eBay and type in cat5e 350MHz and find some cable from there, but otherwise I'd not bother with Maplins at all[/QUote
    Many thanks to all again. Love this site and i will be telling my friends.
  10. #115
    Jun 2012
    Quote Originally Posted by Devilfish View Post
    Telnet Commands
    To flash an image using Telnet
    This method will only work with a .img image file.
    • Rename the image file to backup.img
    • FTP the image file to the /tmp folder on the dreambox
    • Telnet to your box and paste the following command:
    cd /tmp && eraseall /dev/mtd/3 && cp backup.img /dev/mtd/3 && reboot
    To telnet, click START > RUN and type Telnet ip.address.of.dreambox
    A command window will appear, enter username root and password dreambox.
    To backup an image using Telnet
    • Telnet to the box and paste the following command:
    cat /dev/mtd/3 > /tmp/backup.img
    • FTP to the box and navigate to the /tmp
    • Here you will find the backup.img file.
    Will the back up cmd work for mac OS?
  11. #116
    Feb 2009
    Quote Originally Posted by leowyk View Post
    Yes. The commands are for the linux receiver. You are only using telnet to send commands to the receiver, hence it doesn't matter what OS you are using to initiate the commands - All you need is a telnet client
  12. #117
    Jun 2012
    How to do this on dreambox 500 HD?
  13. #118
    DK Veteran DBTraitor's Avatar
    Feb 2011
    Singapore & Malaysia
    [ame=http://www.youtube.com/watch?v=S8gXphh8v5A&feature=related]Flash Dreambox using FTP & Telnet - YouTube[/ame]
    A wise man learn more from a foolish question than a fool can learn more from a wise answer.
  14. #119
    Junior Member jiangou2007's Avatar
    Oct 2010
    hi all,
    my DM500C cannot flash by Dreamup and Telnet method.
    Is Jtag able to recover it?
  15. #120
    Aug 2012
    i never succeed flashing the image through telnet. my box become dead box. is there any do and dont or pre-configured/ step that need to be done before using the telnet methods.
