Page 1 of 8 123456 ... LastLast
Results 1 to 15 of 120
Hybrid View
    Administrator
    Devilfish's Avatar
    Feb 2008
    /cdk
    Default Keys, SoftCams and Emulators (EMU)
    There are two types of channel that are sent out by the cable company; FTA (free-to-air) and encrypted.
    Free-to-air channels are basically freeview channels. You don't need to subscribe to a package to get these channels. If you use an image without an emu or keys you would still get these channels.
    Encrypted channels are channels that the cable company want you to pay for. These channels are encrypted before being sent out and normally you would pay the cable company for a smartcard which you would slot into your recevicer and this will allow you to receive the encrypted channels. It's kinda like when you buy software and you get a key with it. You won't be able to use the software without knowing the key.
    Keys are also included in the cable stream. Normally your digital smartcard will extract the keys from the stream and store them in memory. It would then use these keys to decrypt the channels when you flick through them. Since we don't use a smartcard with a dbox we need something else to decrypt the channels. This is where the softcam (also known as a cam or emulator (emu)) comes in. The box or image itself doesn't know what to do with the keys, it's the softcam that grabs the keys from the stream and stores them in a file (keylist.txt, Autoroll.key, Autoupdate.key). If the keys are changed by the cable company the softcam will update the keys stored in the file.
    The enctytion that the cable company usesis called Nagra1. So we also need to include nagra rom files in our images. These go in /var/scce and /var/keys.
    There are several different softcams that we can use; evocamd, mgcamd, newcamd & gbox. It doesn't really matter what one you use, they all do the same thing. Some emu won't work in certain areas or on certain providers so it's good there are alternatives. The emu can also cause problems with direct recording over ethernet so if you have a blocky recording, try changing the emu or the tuner driver.
    Get Digital Kaos on your Apple or Android device with Tapatalk
  2. The Following 5 Users Say Thank You to Devilfish For This Useful Post:
    billybob69 (15th April, 2014), nongnong (23rd February, 2014), pirsquared8 (27th April, 2013), TCBigsy31 (7th August, 2013), technocell (1st March, 2014)
  3. #2
    May 2008
    thanks for the concise and informative post Devilfish , im new to the dbox , though not to linux , just starting to build up a picture of how all the pieces fit together
    Newbie pabble's Avatar
    Jun 2008
    Lancashire UK
    always wondered how it all happened
    Junior Member balikuyu's Avatar
    Jul 2008
    Default Help needed
    Rom 7 is the only rom needed this was new to me, of all the other forums this forum is impartial and teh most informative, thanks mainly to good administrators and members
    Keep up the good work
    Cheers
  6. #5
    Jul 2008
    Good stuff, im learning all the time on here.
  7. #6
    Jul 2008
    Thanks m8. My Commando 6 is not auto updating, what should I do? The dbox was switched off for one year.
  8. #7
    V.I.P. Member father ted's Avatar
    Feb 2008
    scotland
    Quote Originally Posted by DrKahn View Post
    its because the roms in that image are now out of date you either flash a new image to your box with up to date files or you can try and install the new ones into your image you have
  9. #8
    Jul 2008
    i have the latest blade trinity image, is that capable of auto updating
  10. #9
    aftermath's Avatar
    Mar 2008
    Quote Originally Posted by shy9010 View Post
    its like any image m8, if where you got it deleted the keys and roms, then no it will not auto update.
    If you can ftp to your box, and look in the keys and scce folders, you will find out.
  11. #10
    Dec 2008
    hi is your latest blade trinity image comanda 9.25 and do it have the new 7rom in it as i am looking out 4 it
  12. #11
    Nov 2008
    Unhappy can any1 email me good image with (AUTO FIX) for Nokia dbox2
    Im still struggling to get my dbox2 up.i tried different images to put into my box(IFA).it was okay.but all the image that I found with no softcams and keys only FTA.
    problem is I cant connect my box to pc to put new auto upde rom7 files.
    so I do need Latest image with all softcams and keys (auto fix )include.Plz Plz email me to (siripaladon@hotmail.co.uk).
    Many Thanks
  13. #12
    Nov 2008
    Default hi can you help me?
    Many Thanks
  14. #13
    V.I.P. Member Herbie's Avatar
    Mar 2008
    Quote Originally Posted by SIRIPALA View Post
    Many Thanks
    I have sent you a link with a full working image check your inbox
  15. #14
    Aug 2008
    Thanks for sharing !
  16. #15
    Sep 2008
    Can i decrypt nagra2 channels using this DIGITAL KAOS v1.1 image ? I have a dump from a local smartcard, which keys i need and how do i store them on dreambox ? Thank's
