Page 15 of 16 FirstFirst ... 510111213141516 LastLast
Results 211 to 225 of 226
  1. #211
    joker01's Avatar
    Jan 2018
    I reread the whole post......they called me about a j11 akl.....I have some doubts.....how do I check the steering lock without a working key???? it fits when the door is opened/closed driver???
    [SIZE=3][I][FONT=impact][COLOR=#ffd700]PUSH THANKS AND REP IF I HELPED YOU !!!!!!
  2. #212
    Feb 2014
    When AKL it does not matter much - they will have to change the electronics inside the car anyway. You just will give them a small hope that it could work out without replacing the modules.
  3. The Following User Says Thank You to autoTkey For This Useful Post:
    p1et (20th March, 2024)
  4. #213
    didi_du_93000's Avatar
    France Paris
    For me Nissan dealer have changed bcm and esl.
    Car always don't start.
    They say me impossible to finish the coding of the bcm.
    Some problem on car affect the programing/coding.
  5. #214
    France Paris
    With new bcm and elv I have this Dtc.
    B27DD-00 BCM - ID INCOMP V/V
    Remote don't work. I can make ign On but no crank.
  6. #215
    joker01's Avatar
    Jan 2018
    "steering not completely locked" means that the operation must be checked and that it is free to lock and unlock correctly???
    during the procedure however the steering wheel and therefore the steering lock must be locked right???
  7. #216
    Jul 2019
    Melbourne, Australia
    Quote Originally Posted by joker01 View Post
    Steering must be completely locked at the start of the procedure, but you also must ensure it doesn't have excessive pressure on it from the wheel so it can retract during the learning of key #1. If you are doing a spare key always check for a reliable steering lock function.
  8. The Following User Says Thank You to Spiritech For This Useful Post:
    joker01 (1st April, 2024)
  9. #217
    fred77's Avatar
    Jun 2019
    Quote Originally Posted by autoTkey View Post
    true, worth getting customer to sign something otherwise be round your house knocking down door!
    especially as these car are getting older now folk won't wanta pay and instead start blame game
    Solidarity with Ukraine
  10. The Following 2 Users Say Thank You to fred77 For This Useful Post:
    joker01 (1st April, 2024), musti418 (2nd April, 2024)
  11. #218
    Sep 2021
    NA
    Reading through those horror stories I tend to stick to @Spiritech on this. Just made a spare key for 2016 Rogue with 284B1-4CE1A, the keydiy fob I paired was defective (one button did not function) so made an autel fob, learned both times with no issues or consequences. The only issues I've faced so far is having an aftermarket remote-starter installed which is tapped into the wiring and hinders learning, so have to actually check if car starts with no battery in the key by tap (or slot for older vehicles), and I tend to let it run for 3-5 min just to top off the battery and avoid using battery support. AKL cars usually do need battery support and lithium booster provides for enough time to finish the job.
    Scarry to read though. Having a limited-liability document to sign for those cars is a good idea though.
  12. #219
    fred77's Avatar
    Jun 2019
    Quote Originally Posted by vov4ik View Post
    You need >13V ideally
    If your lithium booster is like mine it also switches so doesn't provide a stable voltage and has a tendency to suddenly stop.
    Ie there purpose is to start the car.
    Saying that we've all thrown the booster on for speed -
    yeah document warning customer and handling such fails may make situation a little easier
  13. #220
    Sep 2021
    NA
    Quote Originally Posted by fred77 View Post
    I use Noco GB70 in forced mode, it provides for 10-15 minutes or so when fully charged. It saves time. Works good on most, except some German and English vehicles. Those actually need 13.5-14v for 20 min or more and drain up to 70amps with ignition on.
    We do have a document to sign prior for those cases for a week now, provides for peace of mind.
  14. #221
    Ecuprog31's Avatar
    Mar 2018
    Hello
    is there any problem with Nissan Micra 2021 remote flip key adding ?( not keyless )
  15. #222
    newone's Avatar
    Oct 2016
    problem only with keyless
  16. The Following User Says Thank You to newone For This Useful Post:
    Ecuprog31 (12th April, 2024)
  17. #223
    France Paris
    Is it possible Nissan dealer have make shit on my car?
    They have changed bcm and esl and car always don't start.
    I have always error from esl Id.
    All part is original and programed is Nissan shop.
  18. #224
    p1et's Avatar
    Oct 2013
    Maybe it's not enough. I read many times need BCM, ELV and ECU. Well all this is so fcked up. Because I know some stories when only BCM was enough. Stupid Nissan
  19. #225
    France Paris
    Quote Originally Posted by p1et View Post
    I think 'Nissan don't know what they make.
    If I can learn myself bcm and keys without risk I don't talk this shit of dealer.
