Page 16 of 16 FirstFirst ... 6111213141516
Results 226 to 236 of 236
  1. #226
    fred77's Avatar
    Jun 2019
    Quote Originally Posted by Spiritech View Post
    Steering must be completely locked at the start of the procedure, but you also must ensure it doesn't have excessive pressure on it from the wheel so it can retract during the learning of key #1. If you are doing a spare key always check for a reliable steering lock function.
    Indeed this is coved in main-dealer bulletin i shared in post long time ago
    Solidarity with Ukraine
  2. #227
    May 2024
    Quote Originally Posted by rapidlocksmiths View Post
    what i do with these on spare key jobs where there is a working key
    1) i remove battery from working key and test the emergency start procedure to ensure ign switch is working
    I have Nissan Qashqai j11 2014 with dangerous BCM and emergency start does not work. What is the reason?
  3. #228
    Sep 2021
    NA
    Quote Originally Posted by Kostazzz View Post
    I would do power reset or look for remote starter install
  4. #229
    May 2024
    Quote Originally Posted by vov4ik View Post
    Yes, car alarm installed with remote start option.
  5. #230
    Sep 2021
    NA
    Default Nissan Qashqai / X-Trail / Rogue Smart Key - BCM's That Are Dangerous
    When they install remote start, they tend (most I’ve seen) to cut factory antenna wiring and tap into a bunch of places, to emulate “valid key in ignition”. All that have to be restored to original to regain emergency start functionality and only then key learning will have a chance to succeed. If you would attempt it now the car will not learn any keys and will stay at where it is until fixed.
  6. The Following User Says Thank You to vov4ik For This Useful Post:
    Kostazzz (5th May, 2024)
  7. #231
    Jun 2013
    Good to be back, logged in again.
    (However been here all the time, every day. But not logged in (because of some login problems - PC related).
    I would think there would be a market for a bench kit solution.
    Like BMW, MB - Kessy cayenne/Toua bench kit.
    Someone, should develop a kit.
    And at the same time.
    Do a research, how to make these modules play together again.
    Firmware upgrade/downgrade. - Reset - Virgin - synch - Add new ECU
    Maybe ELV emu -ON/Off (Test environment).
    Antenna keyless module - start button
    Synch BCM against ECU
    Develop a unique software.
    Or just implement, in whats there already.
    I think this would be much appreciated, probably also by dealers.
    Since I know, they also have these problems.
    And also all other workshops around the world.
    Would be a hole lot of money saved, for customers and other parts involved.
    Warranty etc.
  8. #232
    p1et's Avatar
    Oct 2013
    Would be better if noone buy those crap cars and no more Nissan on the road
  9. The Following User Says Thank You to p1et For This Useful Post:
    Fallen (16th May, 2024)
  10. #233
    szengen's Avatar
    Jan 2017
    life would become boring
    fang, Narwalus microcephalus,Spectrum Zx, Atari amiga, Commodore +4
  11. #234
    Jul 2019
    Melbourne, Australia
    Quote Originally Posted by p1et View Post
    Well the good and bad news is the model(s) in question only lasted less than 10 years, and they've been replaced with entirely renault based platforms.
  12. #235
    avital's Avatar
    vagimmocalculator.com
    Quote Originally Posted by Weasel3 View Post
    Warranty etc.
    I have fitted probably a hundred emulators to cars with a defective BCM by locksmiths in many European markets, and no customer has ever minded having an emulator instead of a key.
    Building a platform is of course possible, but in practice the locksmith customer always chose the emulator over repairing the original BCM - because of the price.
    Production and development professional IMMOBILIZER/TCU/ESL/ELV/SRS emulators for all brand cars
    PORSCHE / FERRARI / MASERATI / LAMBORGHINI - immobilizer solutions
    VAG IMMO CALCULATOR SOFTWARE
  13. The Following User Says Thank You to avital For This Useful Post:
    p1et (16th May, 2024)
  14. #236
    fred77's Avatar
    Jun 2019
    Quote Originally Posted by avital View Post
    didn't think BCM can be repaired - as that's why so complicated/expensive
    but if your saying steering lock emulator solves this issue then great
