Page 2 of 16 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 226
  1. #16
    jodge's Avatar
    Mar 2017
    For me it's simply. I always tell to the customer this problem (with the simpliest ways possible) and asking a written permisson. Every responsibility is theirs.
  2. #17
    Dec 2010
    Nottingham
    getting customer permissions or disclaimers or permission to proceed at their risk signed up may protect some but not others , its not something id like to take a punt on with british courts and uk trading standards , the legality of such a document with our snowflakes is questionable at best.
  3. The Following User Says Thank You to rapidlocksmiths For This Useful Post:
    godfathertwo (27th November, 2022)
  4. #18
    jodge's Avatar
    Mar 2017
    Quote Originally Posted by rapidlocksmiths View Post
    Yepp thats the reason why i asked my lawyer to wite this permission form. She have an insurance too But without joking...no one ever take a risk after i correctly told them the situation. My advice is always the same: try it with the dealer but with insurance covered. (There is an insurance form here if you take the 10% the other 90% cost is on the insurance company) maybe the dealers messing with a single car owner but never with the insurance companies
  5. #19
    Aug 2016
    if BCM is bricked. will there be Faults or DTC in any off the modules.?
    tnx
  6. #20
    fred77's Avatar
    Jun 2019
    Quote Originally Posted by BenzMan View Post
    tnx
    The fact car doesn't start no more might be a clue
    but would of thought so
  7. #21
    Jan 2017
    USA ����
    I'm surprised by the fact that nobody seems to know what exactly happens to these BCM to make them brick
    Anybody got any idea?
  8. #22
    Aug 2016
    i have 2015 nissan Rogue,
    all keys lost (proximity)
    BCM 284B 14BA1A
    no DTC in BCM
    proximity key is new unlocked
    in the procedure after touching the Start Button with Remote. dash should light up and security light should blink 5 times. Does not happen.
  9. #23
    Sep 2019
    I thought truecode was safe to use on these, apparently it detects the effected types and warns the user, i dont have that module and and never done 1, as their not popular in my country
  10. #24
    Aug 2016
    can a used bcm with same part number be adapted?
  11. #25
    Jan 2017
    USA ����
    Nobody even knows why it gets bricked so maybe?
  12. #26
    scotland clydebank
    Why would you risk it surely the job does not pay enough if you accidentally brick one plus not all known bcm module have been found so not safe enough do these jobs why risk.
  13. #27
    armpower's Avatar
    Jun 2009
    Italy
    Hallo
    Interesting topic.
    Will BCM failure only happen with proximity key version ?
    Recently I've done two Qashqai 2017 with regular remote key (not proximity) without problems.
    I've coded the keys with Con sult3 connected to a J2534 interface.I've used AVDI to generate the PIN code and insert manually in the software.
    It's interesting to see if this Bcm' failures are possible only with aftermarket key tools or happen also with original tool.
    Only a Nissan expert or autorizhed workshop can answer this question i guess.
    If only aftermarket key tools are responsible of BCM failure than Con-sult 3 plus Pin code generator are the only safe solution.
  14. #28
    Dec 2010
    Nottingham
    mechanical keys / flip are not affected by this , these are safe to do , this only affects the proximity keys , and even the main dealer tool kills these as well , no tool can do an affected unit not even consult , this is why the dealers had a technical service bullitin warning them of this issue and the new parts required to sort the car. new bcm , new steering lock and one other unit i read somewhere. so if a bad unit then your consult will also kill it.
    truecode is safe in as much as it warns you of the bcm serials it knows to cause issues , but it doesnt know them all as at least 2 not listed were killed on here with different serials to truecode lists .
    bear in mind some have had success on all of the known bad bcm serials , and some seem to be 50/50 pot luck , so the risk is there on all proximity systems for these , its up to you if you want to risk it or not , what is crucial on these is voltage so if taking a chance use decent battery support unit to maintain voltage , those succeeding on some of these all had in common that they used good battery support , alot who killed them did not , so may be a factor .
    the deciding factor for most is Risk versus reward , is the profit worth the risk and how many cars miust you do to recover the loss from having a go.
  15. The Following 7 Users Say Thank You to rapidlocksmiths For This Useful Post:
    A22 (2nd May, 2020), armpower (2nd May, 2020), godfathertwo (2nd August, 2022), issam216 (20th December, 2022), musti418 (3rd May, 2020), ranchero (19th May, 2020), trinicolin (2nd May, 2020)
  16. #29
    armpower's Avatar
    Jun 2009
    Italy
    Thank you rapidlocksmiths
    It's the sort of info we need to avoid loss of money and also image.
    It's better to send the car to main dealer.Probably in event of BCM failure the dealer is supported by Nissan (with new spare ).
    Probably is a bug in Bcm internal firmware.
    The next interesting thing will be.Anyone with bricked BCM have tried to read MCU or eprom to see if it's reparable?
    Thanks to all for valuable info and shared expertise.
    Cheers
  17. The Following User Says Thank You to armpower For This Useful Post:
    mchalisn (29th May, 2023)
  18. #30
    jodge's Avatar
    Mar 2017
    nope i was readed and following all stories here and other fourms too. Only dealer. If they find an affected BCM they must have to replace before the key learning. Somebody posted a service bulletin about this. If the car already killed they will need engine ecu, (bcose the dealer not virginize used ecu) bcm, and 2 keys plus online coding with Consult . Fckn fortune
    PS: and the BCM mcu is with locked JTAG port no way to read or write only OBD
