Results 1 to 12 of 12
    Mar 2019
    Polska
    Default Carprog I cant read eeprom 95160 controller temic Zafira b
    cześć, mam problem z odczytem tematyki sterownika eeprom 95160 z Opel Zafira.
    Używam Carprog 8.21 z adapterem a6. jeśli spróbujesz odczytać eeprom, zobaczę 00000
    badziewo's Avatar
    Feb 2016
    Universe
    Clean eeprom legs and try again.
    Mar 2019
    Polska
    I cleaned Leg a sharp knife. It did nothing
    badziewo's Avatar
    Feb 2016
    Universe
    If you can’t read it on board desolder the IC and read it in the eeprom socket.
    Mar 2019
    Polska
    Ok, i try morning
    Mar 2019
    Polska
    I still can't read. I tried to read Peugeot 206 95089 and it goes without a problem. is something wrong with my device?
    hello no cp is read serie 95 you read 95089 your eepromm95160 is dead new eeprom ans write bin for is ecu and recode on diagnostic
  8. The Following User Says Thank You to romucifer For This Useful Post:
    rajszek94 (23rd January, 2020)
    Mar 2019
    Polska
    I buy a new eeprom and saved it.
    The direction indicators no longer blink.
    I have errors that I can't fix.
    Attached is a file from the web or can someone check it?
    B0015-04. the belt tensioner is new
    B0051-00
    B1000-39
    B0085-71
    B1000-4c
  10. #9
    [QUOTE = rajszek94; 3775390] J'ai acheté un nouveau eeprom et l'ai enregistré.
    Les indicateurs de direction ne clignotent plus.
    J'ai des erreurs que je ne peux pas corriger.
    Un fichier du Web est joint ou quelqu'un peut-il le vérifier?
    B0015-04. le tendeur de courroie est neuf
    B0051-00
    B1000-39
    B0085-71
    B1000-4c [/ DEVIS]
    send me number for ecu please
  11. #10
    Mar 2019
    Polska
    Temic 13241766
    Ecu Bosch 55198922
  12. #11
    hello is dump is clear but you have correct dump for is ecu?test other dump
  13. #12
    Mar 2019
    Polska
    Today i write a few dumps with no effects .
    maybe someone has a dump to my driver?
