Page 15 of 19 FirstFirst ... 510111213141516171819 LastLast
Results 211 to 225 of 271
  1. #211
    Meat-Head's Avatar
    ON TOPIC:-
    not clickbait but one shitty advert ritch bandwitch sucking site
    if somebody can LEEECH the text and photo
    thankkssssss
    http://www.roadandtrack.com/car-cult...oscopic-crack/
  2. #212
    Meat-Head's Avatar
    Vivario/traffic2 bearings go in te shipowner iShit
    the aux belt bearing goes, sideways and feeds belt to crankshaft to join canbelt
    ate high point 16 valve breaking noises
  3. #213
    Mar 2017
    My little sister fiat 500 license plate lights were not working, looked around for a replacement, fiat wanted me to replace the entire trunk handle for a ridiculous price. So I just cutted the light housing open and placed some leds with resistors for a 2usd cost.
  4. The Following User Says Thank You to wokcz For This Useful Post:
    Stelaras26 (27th December, 2017)
  5. #214
    Meat-Head's Avatar
    ON TOPIC:-
    due to (iShit Failiure) and android failure cant show link
    SCENE:-
    fiat scudo, peugoet expert, citroen dispatch the later 2007 onwards
    SCENE 2
    Bloke walks rounds, confirms its locked.
    SCENE 3
    rear sliding door, back corner, bottom edge, small locksmiths airbag
    pump pump hand under door, tugs
    SCENE3
    KERCHUNG central lockung unlocking noises opens door
    total time elapsed 30 seconds
  6. #215
    Meat-Head's Avatar
  7. The Following 2 Users Say Thank You to Meat-Head For This Useful Post:
    maybach_ (17th April, 2018), Stelaras26 (27th December, 2017)
  8. #216
    Meat-Head's Avatar
    Not sure if mentionec or not but worth mentiong again if notcorsa c
    clutch master cyclinder, pig to get off, but WELL WORTH 7 BOKTS, steering colon out
    extract madrer cyclinder and do it on the bench
    whi
    te pladtic important and not availble seperatoy
  9. #217
    Dunker's Avatar
    Yorkshire
    Renault CAN Clip stupid ridiculously short lead between interface and OBD plug. ~~~~ERS.
    V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
    IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
  10. The Following User Says Thank You to Dunker For This Useful Post:
  11. #218
    Meat-Head's Avatar
    Quote Originally Posted by Dunker View Post
    CAUTION ADVERTISEMENT:-
    https://m.gendan.co.uk/product_OBD3M.html
    also great for cars with them strong airsfreshners you eg
    ie "wet dawg", "dawg and redbull" or "redbull and cigrettes"
  12. The Following User Says Thank You to Meat-Head For This Useful Post:
    Dunker (28th December, 2017)
  13. #219
    Dunker's Avatar
    Yorkshire
    Not 100% ideal but it must be better than t'ridginal.
  14. #220
    rideon's Avatar
    RO
    No comment....
    A failure will not appear till a unit has passed final inspection
  15. The Following User Says Thank You to rideon For This Useful Post:
    Meat-Head (15th April, 2018)
  16. #221
    Mar 2018
    albania
    as i see no one has ever worked on a reno velsatis 3.0 dci automatic or peugeout 407 3.0 hdi these are on my opinion the mothers af all f**ed up cars
  17. #222
    Meat-Head's Avatar
    ON TOPIC:-
    was as talking to an estates agent called Randell and he was a bit pompous.
    but that's not important right now.
    landrover adblue is black tank so you can't see the level, overfill won't start even if you drain any off
    on tow truck to dealer, well that helps the environment doesn't it!
  18. #223
    In every MODERN FORD: cabin filter lots of time to replace.
    Why do you put 2 screws 7mm and you have to remove throttle pedal
    while in other cars you need to unclip something and unclip the filter holder and YOU'RE DONE!
    What's wrong with Ford engineers?
  19. #224
    Meat-Head's Avatar
    ON TOPIC:-
    those with acess to repair times fiat stevio aerial change 7.90 hours
  20. #225
    Jun 2018
    K12 Nissan Dikera to change fuse under bonnet headlamp out, to get the headlight out bumper must come off, grill off wheel arch liner off to get at bumper bolts then the bumper bolts don't f""kin screw without bending the wings!
    Better to scrap them than face the bill of checking fuses!
  21. The Following User Says Thank You to Black dog For This Useful Post:
    Meat-Head (17th June, 2018)
