Page 2 of 19 FirstFirst 123456712 ... LastLast
Results 16 to 30 of 271
  1. #16
    renault modus, complete front end off just to replace headlight bulb .
    main dealer charges ?180 to fit 2 bulbs costing ?8
  2. #17
    French cars. If one pulls up to the garage i write a cheque out for 50.00 and give it to the driver before telling them to piss off,it works out cheaper in the long run!!!!!
  3. #18
    Meat-Head's Avatar
    Quote Originally Posted by dik View Post
    , Now what car was it that you used to have to cut a hole in the bulkhead to remove the camshaft possibly a Renault? French Bast**ds
    before my time, but MK2 Escort, the thing with a fixed jet carb, inertia starter ballast wire in loom, anky fusebox never remove jump leads after starting, blows tacho
  4. #19
    DK Veteran BeianM's Avatar
    Dorset UK
    Quote Originally Posted by Dajan2009 View Post
    Oh, yes, If You want to drive a alfa and to change the timing belt all by yourself, you are in love with that car!
    Quote Originally Posted by rideon View Post
    Just remember,anyone tried to change (all) the spark plugs on a V6 espace?
    Both my favourite cars
    2ltr Alfa 156 Sportswagen, cam belt went on me on the M3 j3. Managed to wind it up the sliproad on the starter, backwards!! but don't tell anyone. Oh there was a service letter about that was there? funny I DIDN'T GET IT! (Service replacement cambelts not lasting its due service) Replacement head in boot at the mo.
    Espace 3ltr auto, needs cambelt & plugs. My mate borrowed it & now it needs a gearbox, did I mention it's an automatic. No wonder there are so many 3ltr autos being scrapped on ebay! This gearbox is supposed to be good for 200k after all merc put in the sprinter, so it must be good. I have a replacement on its way from a laguna, it was cheaper than buying all the parts as it has all been done & is lower mileage, going to be interesting trying to get a five speed box working in an original 4 speed. May end up looking like an Avantime!!
    Ever had to replace the heater matrix on the Espace, almost impossible to get to the hoses without dropping the engine from it mounts, then you have to remove the dashboard made from a million parts.
    Now going back to my aprentice days at a Leyland Dealership, it was never a good idea to have the gearbox strapped under the engine sharing the same oil like they did on the mini. Which found itself in the Allegro. I did so many warranty replacements that if we did not have a complete replacement gearbox I could do a removal, recondition the box & get it back in the car in one day. Those were the days!!
  5. #20
    top thread, love doing the rover 75 v6 cam belts there great, and lets not forget the "one way" bolts holding the ecu's in on the renault masters after they have been exposed to the elements for 8 years.
    a close second are the bolts made from plasticine on the rover k series holding in the alternator.
    Renault laguna window regs
    berlingos/partners when the good old screen folks didn't quite get the bonding area quite right for a change, (it does have a small target area) and it fills the bsi with rain water.
    vw group temp sensors.
    seat exterior temp sensors in the n/s mirror
    all coolant temp sensors
    diesel fuel temp sensors.
    saab drive shafts.
    fiat stilo headlamp bulb td with inter-cooler in the way
    late honda civic diesel filter
    Most pollen filters espically volvo c70's i'll just remove the fusebox brilliant now nothing works and all needs setting up again, sorry sir the electric roof doesn't work after your service, can't imagine why. What would happen if you had to unplug a peugeot or shitroen fuse box every service it would be chaos even more ~~~~ed bsi's and dead vehicles.
    these are just the ones I though of today if I sat down there would be loads.
    Ted
  6. #21
    Liteace's Avatar
    Mar 2009
    On a rock
    vauxhall chevette starter motor, triumph stag clutch
  7. #22
    DK Veteran Wolfpack's Avatar
    New York U.S.A.
    Thank god i don't do any of those jobs anymore. I only check out those problems and i only do electronic and electrical work. I have to say any job you need to remove the motor really su*ks. How do you replace the starter on a VW tourag you remove the motor. How do you replace the cats on a 2.7 turbo Audi you remove the engine. Now how stupid is that. On the other side how stupid are the flow charts when you are checking an engine code and it's says "Try a Good known Part" sure i have a $500 ECU laying around just to try. Always remember some things are very hard to do but others are so easy. One trick i have learned working on German cars is if you start to think like a German then you will realize why it was built like that.
  8. The Following User Says Thank You to Wolfpack For This Useful Post:
    Louislesinge (3rd September, 2020)
  9. #23
    Nearly forgot, new shape landrover electronic handbrake thats been parked in the north sea for a month. Try changing the unit, enough to make you eyes water.
    Ted
  10. #24
    DK Veteran dik's Avatar
    Apr 2009
    In a mental institution
    Quote Originally Posted by Liteace View Post
    How about tr7 cylinder heads, remember they put one row of head bolts in at an angle and one row straight, thankfully they put a useless slot in the stud so you could remove them with a screwdriver - what bollox, I remember removing big end caps and sledge hammering the pistons against the head raising it up 2mm then cutting through studs with a air saw, then having an engineer drill out the studs from the head
    another happy customer
    Sent from my keyboard using fingers to type
  11. #25
    freelanders...
    old diesel engine no4 glow plug with injector pump removal with no key on the pump, Excellent. Also the power-steering pumps are fun.
    Ted
  12. #26
    Liteace's Avatar
    Mar 2009
    On a rock
    Opel corsa B wheels that stick out a good inch and a half past tyre so when ya missis parks she scuffs the ~~~~~ out of them
  13. #27
    Oct 2011
    Quote Originally Posted by big-ted View Post
    Ted
    That's why EU cars only need to remove the throttle pedal and hope the nuts don't get stuck
  14. #28
    Meat-Head's Avatar
    Had one the other month - jeep & scum of the earth cranking sensor
  15. #29
    Sep 2008
    mercedes a140 starter motor never got to see the car ,was told 5 1/2 hrs fitting time and gearbox needs to be dropped and the cars not worth it.99d reg
  16. #30
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    Quote Originally Posted by party7uk View Post
    the world has gone mad m8 Renault Modus headlight bulb guide or is it just the french
