Page 3 of 19 FirstFirst 1234567813 ... LastLast
Results 31 to 45 of 271
  1. #31
    Meat-Head's Avatar
    Quote Originally Posted by smirnoff_rules View Post
    the world has gone mad m8 Renault Modus headlight bulb guide or is it just the french
    A few months ago had a fellow trader in - bit of a pannick - Reanault Megraine - with the arse sticking out.
    Basically it was an a/c fault, he had probed, prodded and regasses, new trianry switch, and was confident in it being the ecu.
    Being specalists in damaging vechiles, the effort required to remove the front bumper, verses struggling and condeming and innconet ecu, nil poi.
    Had the bumper off in seconds (standard Frogench remove the visable screws - then close eyes and yank) - wire had pulled out of the trianary switch.
    The hardest part of the job was fixing the 1 wire - the rest was really easy.
    Total time, including insults was 1 heure.
  2. #32
    Liteace's Avatar
    Mar 2009
    On a rock
    It is just the frogench, over the years what have been the hardest to work on, no thought what so ever goes into general maintenance, like for for example changing the oil and filter, on most of the jap cars the oil filter is just above the drain plug on the same side of the engine, you can drain oil and change filter into a small container in one go and not make a mess, unlike the Rens, the models with air con you can get anything on the ~~~~~ing filter to get it off, when you do the oil runs down the front of the engine and sits in the ridge at the bottom of the block then drips off the whole way along onto the subframe and makes a right ~~~~ing mess
  3. #33
    Meat-Head's Avatar
    *BRILLIANT* re-found this thread by accident, now forgot what was going to say
    Quote Originally Posted by cactikid View Post
    mercedes a140 starter motor never got to see the car ,was told 5 1/2 hrs fitting time and gearbox needs to be dropped and the cars not worth it.99d reg
    No mate, just remove the inlet fannymould.
  4. #34
    DK Veteran m3vuv's Avatar
    woodhall-spa lincs
    what about the old sries 1 2 and 3 jag xj6 rear handbrake pads,or rover 2000 for that matter?
  5. #35
    Meat-Head's Avatar
    what was that?
  6. #36
    woodhall-spa lincs
    miss type,meant to say series 1/2 or 3 jaguar xj6 handbrake pads.
  7. #37
    Meat-Head's Avatar
    so what is bad about them?
    remembered, unconfirmed rumor, freeloadeer, oilfilte r butt up rsdradiator
  8. #38
    woodhall-spa lincs
    inboard disks and a total **** to get at!
  9. #39
    DK Veteran dik's Avatar
    Apr 2009
    In a mental institution
    I vaguely remember a shitroen where to change the exhaust front pipe you needed to take the engine out so I cut the new pipe in half got both parts in then welded it back together
    another happy customer
    Sent from my keyboard using fingers to type
  10. #40
    woodhall-spa lincs
    had one like that back in the 70s,think it was a flat 4 gs club
  11. #41
    The best thing to come out of france was the road to belgium
  12. The Following User Says Thank You to autotrans For This Useful Post:
    nascenta (2nd November, 2015)
  13. #42
    quinnd's Avatar
    Jul 2012
    NZ
    D22 Nissan Navara, VP44 pump change. Crap job anyway but having to slide gearbox back to remove sump to remove lower timing cover to remove chain?? Stupid.
  14. #43
    DK Veteran ghostridersa's Avatar
    Nov 2011
    Audi S4 V8 must be the worst ****-up as it takes 15.9 hours labour to change a exhaust manifold. I thought the people were talking crap until I did a couple myself. Complete front end off vehicle, radiator, air-con, complete engine, wiring loom, you name and you have to remove it. Autodata lists it as 15.9 hours chargable but its more like 25 hours to replace them.
  15. #44
    smirnoff_rules's Avatar
    Mar 2008
    birmingham
    changing fan belt and adjuster Pully on a jag x type 20 diesel then having to remove alternator and then crank Pully to force belt back on
  16. #45
    Meat-Head's Avatar
    2.0 diesel then having to remove alternator and then crank Pully to force belt back on
    Cool, can you expliain in more detail, how you get the belt back on.
    We get the odd one for a new dynamo, bastawrd to get the belt back on.
