ON TOPIC:-
not clickbait but one shitty advert ritch bandwitch sucking site
if somebody can LEEECH the text and photo
thankkssssss
http://www.roadandtrack.com/car-cult...oscopic-crack/
ON TOPIC:-
thankkssssss
Vivario/traffic2 bearings go in te shipowner iShit
the aux belt bearing goes, sideways and feeds belt to crankshaft to join canbelt
ate high point 16 valve breaking noises
My little sister fiat 500 license plate lights were not working, looked around for a replacement, fiat wanted me to replace the entire trunk handle for a ridiculous price. So I just cutted the light housing open and placed some leds with resistors for a 2usd cost.
Stelaras26 (27th December, 2017)
ON TOPIC:-
due to (iShit Failiure) and android failure cant show link
SCENE:-
fiat scudo, peugoet expert, citroen dispatch the later 2007 onwards
SCENE 2
Bloke walks rounds, confirms its locked.
SCENE 3
rear sliding door, back corner, bottom edge, small locksmiths airbag
pump pump hand under door, tugs
SCENE3
KERCHUNG central lockung unlocking noises opens door
total time elapsed 30 seconds
Hate editing posts
https://mobile.twitter.com/kev_south...61433445097473
maybach_ (17th April, 2018), Stelaras26 (27th December, 2017)
Not sure if mentionec or not but worth mentiong again if notcorsa c
clutch master cyclinder, pig to get off, but WELL WORTH 7 BOKTS, steering colon out
extract madrer cyclinder and do it on the bench
whi
te pladtic important and not availble seperatoy
Renault CAN Clip stupid ridiculously short lead between interface and OBD plug. ~~~~ERS.
V Series TMS470 / EEPROM data - encryption / decryption, totally pwned.
IEC 62056-21 - new discussion: sonsivri.to/forum/index.php?topic=60412.0
CAUTION ADVERTISEMENT:-
https://m.gendan.co.uk/product_OBD3M.html
also great for cars with them strong airsfreshners you eg
ie "wet dawg", "dawg and redbull" or "redbull and cigrettes"
Dunker (28th December, 2017)
Not 100% ideal but it must be better than t'ridginal.
No comment....
A failure will not appear till a unit has passed final inspection
Meat-Head (15th April, 2018)
as i see no one has ever worked on a reno velsatis 3.0 dci automatic or peugeout 407 3.0 hdi these are on my opinion the mothers af all f**ed up cars
ON TOPIC:-
was as talking to an estates agent called Randell and he was a bit pompous.
but that's not important right now.
landrover adblue is black tank so you can't see the level, overfill won't start even if you drain any off
on tow truck to dealer, well that helps the environment doesn't it!
In every MODERN FORD: cabin filter lots of time to replace.
Why do you put 2 screws 7mm and you have to remove throttle pedal
while in other cars you need to unclip something and unclip the filter holder and YOU'RE DONE!
What's wrong with Ford engineers?
ON TOPIC:-
those with acess to repair times fiat stevio aerial change 7.90 hours
K12 Nissan Dikera to change fuse under bonnet headlamp out, to get the headlight out bumper must come off, grill off wheel arch liner off to get at bumper bolts then the bumper bolts don't f""kin screw without bending the wings!
Better to scrap them than face the bill of checking fuses!
Meat-Head (17th June, 2018)
