Vauxhall Opel CD70/DVD90 Software Upgrade Disk
Page 1 of 5 12345 LastLast
Results 1 to 15 of 72
    Default Vauxhall Opel CD70/DVD90 Software Upgrade Disk
    Does anybody have access to the latest CD70 Navi Upgrade Disc.
    caveman_nige's Avatar
    Feb 2008
    In my Cave
    if its maps, about 5 threads down from this one... or are you after the software disk?
    http://www.digital-kaos.co.uk/forums...-2010-a-77552/
    Quote Originally Posted by caveman_nige View Post
    It's the software/firmware upgrade sisc i'm after. I have the 04/2007 version but I understand that there is also a 10/2007 version which is the latest
    Feb 2008
    In my Cave
    what will it do for the CD70?.. I did not bother and just used an updated map cd with no probs..
    I will ask if I can borrow one from somebody (so long as he has one).. If he does have one i will make and image and post links on here..
    Feb 2008
    In my Cave
    Post
    try this, its a Nero image (.nrg file) about 60Mb
    http://www.mediafire.com/?zd1ymvzlkn1
    On the CD it says:
    Opel/Vauxhall Media Portal
    Lanaguage CD
    Software
    Version 2005 | 1.0
    CD70 Navi, DVD 90 Navi
    On the CD it says:
    Lanaguage CD
    Software
    Version 2005 | 1.0
    Thank Nige, but that's just the language CD and already have that one.
    Cheers anyway
    Feb 2008
    In my Cave
    have yet to come across that one, will keep looking.. Can you make an image of the software/firmware disk that you currently have for sharing, I wouldn't mind have a copy to try out, not sure what level mine is at?
    Did you find the 2009-2010 software update disc?
    Feb 2008
    In my Cave
    the last software cd made for these was dated 10/2007 is that the one you want?
    To check you software level do this:
    Press and hold the SETTINGS button until you hear a 'bong' - the unit is now in Testmode.
    Press AUDIO 3 or 4 times once in testmode to scroll through screens until you get to SOFTWARE.
    Look for the software date - it's in the format 10/10/2007.
    You will see from the edited pic that it is a 2005 and therefore needs an update...
    Feb 2008
    In my Cave
    Arrow CD70/DVD90 software update
    I used a genuine CD to do mine that somebody kindly loaned me.. This image is extracted from a torrent and in turn reuploaded to mediafire as a .rar file... Extract the rar and it produces a .nrg file... Use Nero to burn this to a decent quality blank CD at slow speed...
    To upgrade to your headunit you must turn the ignition on, remove you audio and maps disks then insert the software CD into the map slot... It will check your current software level and if it can update the HU it will ask if you wish to proceed. The update takes about 5 - 10 mins to complete. Your saved radio stations will be cleared but your saved navi destinations should remain. Once completed the CD will reject itself and quickly reboot the headunit..
    DO NOT SWITCH OFF YOUR IGNITION DURING THE UPDATE.
    http://www.mediafire.com/?ltwlgmdyqbl
    Disclaimer: This software is stored on an external site and your use of it is entirely at your own risk. Digital Kaos and its members are not responsible for any damage caused as a result of software used whether it is from this site or links to external sites.
    hi nige what updates does this give to the head unit and i i am just double checking that its for a cd70 navi just so i don't brake anything as i am good at that
    Feb 2008
    In my Cave
    "differences appear to include some spelling corrections, adding Aux In support, map auto zoom changes, longer MP3 track names and probably a whole bunch of other things you'll never notice" not my words.. i did not notice any difference..
  13. #13
    Downloading the one you posted. I will install it tomorrow and get back here. My current ver. is 04/2007.
    Later edit: @caveman_nige: from what I see it's the same version, 04/2007. The size it's the same, 140 MB. Care to post the newest version (10/2007) on the web?
  14. #14
    Feb 2008
    In my Cave
    Quote Originally Posted by Tot eu View Post
    did you try it though? I had checked the files inthe download and they were the same as the files on the original disk... There isn't a newer version than this one as Vauxhall/Opel stopped installing the CD70/DVD90 after 2008 i believe..
  15. #15
    I had the car in service for some repairs, but today I'll definitely try the firmware. I'll get back.
