Results 1 to 4 of 4
    Aug 2011
    puerto montt
    Default Cruze cluster problems
    Hello everyone, I tell you. I am in a Chevrolet Cruze Eco, 1.8 engine with automatic transmission. The problem started when the drivers of the lights burned, with the problem of the shipments I decided to buy a new BCM. Copy the EEPROM memory, all good the vehicle started, without an error code, everything working, but on the board it does not mark the RPM, nor the gear selection ...
    I ran out of ideas ...
    Has it happened to someone?
    Thank you very much to all.
    jomberykaso's Avatar
    Sep 2013
    En algun lugar de Chile
    post files from dash and bcm
    Aug 2011
    puerto montt
    Here are both 24c16 files, they are the original ones since I have never modified them. ...Thank you very much for your prompt response
    Aug 2011
    puerto montt
    Thanks anyway, but I was able to solve the problem ... the vehicle configuration is not found in the EEPROM 24c16, it is in the microcontroller d70f3385. In case the data is useful to someone ...
