Results 1 to 15 of 17
    Jun 2020
    Default Toyota : virginize immo box eeprom (93LC66) to enter key learning mode
    Hello everyone,
    I'm in a all keys lost situation with my toyota hiace 2008 being stuck in very small mountain village.
    After lot of research on internet here is what I would like to do:
    Get new cutted keys from a Toyota dealer with my VIN. (done)
    Get the immobox from my vehicle 89780-26141. (done)
    Dump the information stored into 93LC66 eeprom. (done see attachement)
    Now the idea from the information a gathered from internet is to virginize this eeprom and put it back into the vehicle to enter learn mode and reister the new keys from the ignition lock.
    I don't have the transponder code from new keys.
    Do any of you my friend have the knowledge to virginize my eeprom dump ?
    In advance thank you.
    Jun 2020
    Default new dump
    The dump of the eeprom with ORG pin set to ground. Hope its better.
    ray-ray's Avatar
    Immo. Read from ecu or separate immo.? 93LC66 read in 8bitmode ? If put to auto learn mode your going to Sinx the immo. To the ecu 4 & 13 for 35min.
    Jun 2013
    EU
    Quote Originally Posted by yeffog View Post
    Hello everyone,
    Don't know if it will work for your needs but i tried to delete your keys, so may be relearnt just by putting in ignition.
  5. The Following User Says Thank You to morgano For This Useful Post:
    yeffog (9th June, 2020)
    Jun 2020
    Hi Ray-Ray
    Sorry if don't use the correct terms or if I miss some information that you have but I'll try to aswer:
    Immo is read from the separate immobilizer box (89780-26141) of my vehicule not the main ECU.
    93LC66 microship is in 8bits page organisation and has been read by desoldering the ship and using CH341 USBtoMicrowire dongle and AsProgrammer.
    Apparently if the synch identifier in my dump is kept as it is, the synchronisation won't be necessary. But of course I will try this if it doesn't work at the first attempt.
    Happy to learn any information that you would have on this topic.
    Jun 2020
    Hi morgano,
    Thank you, can I have the password to open the archive ?
    As engineer I would be very interrested to know how you did that
    Cheers
    Jun 2013
    EU
    Hi morgano,
    Cheers
    Mate, you have it on your PM since the moment i uploaded file to thread.
    ray-ray's Avatar
    4D 67/68 have the same auto learn file, do a search “Gwee” broke it down.
  10. #9
    Jun 2020
    Someone told me it is 4C so how can I know ?
    I have searched this forum for hours, compared tenth of dump trying to understand how do the same for mine but no results.
    The closest I have been is this thread : https://www.digital-kaos.co.uk/forum...ht=89780-26140
    The dump is very close to mine but not exactly probably beacause mine is 89780-2614(1) and not 2614(0).
    If I'm not wrong Gwee is not on this forum anymore...
    I have techstream but I'm in europe so immo reset won't work I guess.
    I will try the dump from morgano and the one from the previous thread but if it doesn't work and if nobody can give the proper virgin dump, does someone could enter the new keys IDs into the dump for me ? Perhaps I will buy the necessary hardware to read the keys.
    Anyway thank you for all you help it is very appreciated
  11. #10
    ray-ray's Avatar
    Maybe these will give you the information 4D 67 or 68 work the same way.
    https://www.digital-kaos.co.uk/forum...Toyota+Sequoia
  12. The Following 2 Users Say Thank You to ray-ray For This Useful Post:
    morgano (10th June, 2020), yeffog (10th June, 2020)
  13. #11
    Jun 2013
    EU
    Quote Originally Posted by ray-ray View Post
    So friend's correct virging should be like this one?
  14. The Following User Says Thank You to morgano For This Useful Post:
  15. #12
    Jun 2020
    Thank you ray-ray this is gold !
    But now I have questions haha
    In my dump, correct me if I'm wrong:
    I think we all got the key regions (first 2 master and then 1 valet repeated 3 times eachone) .
    03030303 sequence is fixed probably to mark end of one memory region and start of another (really not sure about that but anyway fixed).
    89 DA 89 DA 89 DA sequence is fixed probably related to the immobox type since it not the same as in sequoia dump
    A binary representation of the key learning and synch steps FF->FE->FC->6C->2C at the very end.
    My question is about the synch sequence, I would say that in my dump it is "DE E8 DE E8 DE E8" corresponding to ""4B 1B 4B 1B 4B 1B for sequoia.
    There is also a "00" byte which is at one place before mariage and then at another place after
    morgano in your virginized version of my dump you kept the mariage sequence "DE E8 DE E8 DE E8" but moved the "00" to the "no mariage/synch performed" location, I'm not sure about that...
    I don't understand the other sequence "23 35 23 35 23 35" fixed and the counter appearing just before which follows the step of key learning and sync... redondant with the FF->FE->FC->6C->2C sequence at the end.
    I don't understand why the "00" byte is not at the same place in the original file and the final maried file of sequioa...
    Hope I'm not too long... and that we see the same number when opening dump file otherwise all this text will probably be just an occasion for my brain to sort its thoughts (which already nice haha)
  16. #13
    Jun 2020
    Ok, thank you everybody it worked with this file !
  17. The Following 2 Users Say Thank You to yeffog For This Useful Post:
    ejoyeux (11th October, 2020), TepiTheFinn (9th August, 2023)
  18. #14
    Jul 2020
    can i get password for this file..thanks
  19. #15
    Mar 2017
    Please pass work
