Results 1 to 3 of 3
    May 2017
    Default EDC 17c46 ECU clone help
    Hi i have vag edc 17c46
    Car ecu was dead....
    So i bought used ecu which is already immo off..
    With new ecu i can start and drive car,but immo active and abs not coded
    Both ecu part numbers are different,and different software but 17C46 only.
    Stock is 110 ps power and new ecu is 140ps power.
    I copied dead ecu's EEPROM & FLASH and write to new ecu.
    But car not starting,it says SAFE message on cluster.
    And 2783-Internal Control module memory
    P160A check sum error
    Can anyone help me to clone to start this car...but i dont want immo off..i need original condition
    Thanks in advance
    May 2017
    Than you need first a same ecu... you can clone truth... only do immo... adjustment.
    May 2017
    thank you so much for your response
